bounce to disk crashes
I cannot get Pro Tools (Project 4.1.1, MAC 7300/180, 7.6.1) to bounce to disk. I follow the steps carefully from the reference guide, but the process crashes after about 15 seconds. It doesn't seem to matter whether I try and make a mono file, stereo interleaved file, or a split stereo file; it crashes no matter what. Also interesting: the reference guide says that I will see "Bounce Source" pop up menu, but it does not appear. All the tracks are set to the same outputs (1 and 2); additionally, when the bounce process starts, it does NOT play back audio (as the ref. guide said it would).
I need to do these bounces to use in Toast. So far I haven't been able to print any CDs... Any suggestions would be greatly appreciated! John |
Re: bounce to disk crashes
John,
Real time bounces only occur on TDM pro tools systems. Sounds like you should check you disk cache. Memory control panel/disk cache setting should be 256k. Hopefully yours is set to a number much higher. That can cause pro tools to have problems bouncing to disk. Other things to check are disk fragmentation - possibly the DAE buffer setting (2-4). B Carter Digidesign |
OK, I reset the disk cache to 256 K (it was at 2560 K for some reason...). I also went to the DAE and attempted to set the playback buffer at 2-4. However, no matter how I set it, it would always revert back to 0. Apparently that didn't matter, because now it's behaving fine. I also allocated more memory to the DAE in the "Get Info" window (11292/22584 K; it was previously set much lower.)
I'm now up and running. Thanks so much for the tip. |
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade | AllThingsMusicStudio | macOS | 0 | 06-28-2012 07:16 PM |
ProTools 9.0.3 HD Crashes after Bounce To Disk | Syncronix | macOS | 3 | 06-16-2011 05:20 PM |
Protools Crashes Everytime When Bounce to Disk | DJtrademark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 09-10-2010 06:30 PM |
Pro Tools crashes after bounce to disk, mp3 | BryanLevay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-16-2007 05:54 AM |
Bounce To Disk now Crashes my system ?? | David Lawler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-23-2001 05:14 PM |
