Old 11-12-2010, 07:16 AM
samplaire's Avatar
samplaire samplaire is offline
Default Video sync offset
When I do a post work I have the PT edit window on one monitor and the related video is displayed on a second monitor (the same type). What setting should I set in the video sync offset dialog if my monitor has 8ms delay? 8ms is less than 1 quarter frame (but close to) when 25FPS. Thank you for your help.
Wojtek
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 11-12-2010, 10:15 AM
Postman Postman is offline
Default Re: Video sync offset
It will probably be 1 or 2 quarter frames but there are variables and measuring is the best way to know. Syncheck can do that. You do not say which codec, some people have reported small changes in offset with different movie codecs, and of course monitors in real life do not behave like their spec sheets imply they will. The best way is to measure with a Syncheck. Second best, IMHO, is to set the offset to 1.
Old 11-12-2010, 10:52 AM
samplaire's Avatar
Thanks for the info! Syncheck seems a good tool. I use different codecs (depends on the file I get from video studios). If it is an MPEG1 or h264 then I usually convert it to apple photo jpeg (because it is compatible with my work PT6). I understand you say '1' not '-1' as the offset. I'll try working with that and then I'll prepare a DVD to see it on my home video system.
Old 11-12-2010, 03:35 PM
mikevarela mikevarela is offline
I'm on dell lcd monitors and usually they run between 2-5 qf. no sync check, just eyes. I also use the guide track to check against when spotting material - that always helps
NuanceTone.com
Old 11-12-2010, 11:22 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I use 4qt frames, and it seems good.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 11-13-2010, 06:07 AM
lae777 lae777 is offline
My manual method is to go to the 2 pop and give pro tools approximately 5 seconds pre roll then press play and enter my offset until the 2 pop sync looks right. You really will know when it is right.
It is amazing how reliable you eyes and ears are!
On the set up I'm currently using I have a 16 quarter frame offset.
Syncheck looks good but I really can't justify the cost.
Old 11-13-2010, 10:49 AM
pindebraende pindebraende is offline
Originally Posted by lae777 View Post
Not trying to be rude, I just dont quite understand the process. Could you please explain exactely how you do this?
Best wishes,
Mikkel
Old 11-14-2010, 02:28 AM
idris idris is offline
I used a Syncheck recently and the results suggested to me the method I think you are using is not viable: I found that the pictcture / video ofset needed would be different EVERY second. One second you could be +0.75, the next second -0.25, the next second +1, the next second -1. It was all over he place. (Your results may vary.)
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 11-15-2010, 09:09 AM
paranerd paranerd is offline
Was the delay jumping around on the SynCheck itself or what it noticeable on screen? I found that having less than fresh batteries in the SynCheck would make it erratic.
The Postman Post-Production Studio
Moncton, New Brunswick, Canada
IMDb (very partial)
Old 11-16-2010, 05:50 AM
It was noticable on screen in as much as it just never looked right, though with the speed of the pips and inconsistency it was a sitution where you kept thinking "it's early ... no it's late ... oh hang on ... no itdefinitely late ... err was that in or out ... oh god I'm going mad!"
The Syncheck showed stable (though driffting) results via a Canopus so I'm pretty confident of the results.
HTML code is On
Video Sync Offset jumps simonchase Post - Surround - Video 21 02-21-2014 08:32 PM
Mojo Video Sync Offset TAFF Post - Surround - Video 4 04-01-2011 11:42 AM
Keeping Laybacks in Sync (delay compensation and Video sync offset) edit machine Pro Tools TDM Systems (Mac) 6 11-15-2010 11:33 AM
Video sync offset changes Studio Studio Pro Tools TDM Systems (Mac) 0 09-15-2008 06:33 AM
Negative Video Sync Offset??? admix Post - Surround - Video 3 05-15-2008 10:34 AM
