Old 09-05-2006, 08:36 AM
ccguitar1 ccguitar1 is offline
Default can\'t monitor inputs
I can't monitor inputs without putting Pro Tools in Record. Everything else works fine...002 as soundcard. Had an Mbox and just upgraded. I could use the Mbox to monitor without recording...anybody know if I can do that with the 002 rack. I'm using a mac.
thanks
Old 09-09-2006, 11:20 AM
JohnnyG JohnnyG is offline
Default Re: can\'t monitor inputs
If you in pro tools 7, go to the top toolbar and choose Track, then 'input only monitoring"
Then you can hear the inputs. Without that turned on, Pro Tools will only listen off the hard drive and only drop into input mode when recording. So in your case you'd want that feature turned on so it's not monitoring off the hard drive while not recording.
Why can't I monitor inputs during playback? danoan522 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2010 12:33 PM
Can I monitor 2 inputs but only record 1 of them in LE? Martin Dubka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-25-2009 10:37 AM
How To Monitor S/PDIF Inputs joseph halloran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-01-2008 12:02 PM
Switching inputs, monitor level goes BAM! mtung ICON & C|24 8 07-07-2006 12:54 AM
monitor inputs to headphones janrudi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2000 08:00 AM
