#51
Re: ProControl with Pro Tools HD 8
do you have another MIDI device to check the MIDI I/O?
I've seen them fail before cables in the wrong ports would be my other thought
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
#52
Thanks craig for your help it was very useful everything is working as it should now.
#53
I just add 2 accel cards to my pro tools set up, but I can not get the digitest to run while all 3 cards are installed. I removed the last card and everything is back to normal, but when the third card is installed the computer recognizes the card. does this mean the card works? even though i can't get the digitest to run?
#54
Apart from digitest! Does pro tools load and run ok with both accel cards? Chris
#55
I have 4 192's connected to my system the primary one is working fine. How and what do I use the other for? and can I connect synthesizer to system as well as an mpc 1000 to make beats? or did i ask to many questions?
#56
I asked for help a couple days ago o and issue I'm having and I haven't gotten a reply yet what am I invisible Please I need help on an issue I'm having thank you
#58
If you have a problem unrelated to the rest of this thread you may be better starting a new thread. Or if you think you need an urgent response the way to get that is to phone and pay for Avid support. |
#59
I want to know what procedure to I take to get my other output sources working on my pro control I have 7&8 working,but I'm have a problem with 1&2 and 5&6 I read the manual,but not quit understanding it help would be appreciated.
#60
Do you actually have the 192 IOs connected and working and can you connect inputs and outputs to them and actually have that work? That is the first step, start there. Then whatever 192 Outputs you want to use for say your surround outputs you need to get from the 192 to the corresponding input on the right input connector on your Pro Control and then the Pro Control will get that to its Output connector. Start at the 192, draw a diagram, Change the IO settings in Pro Tools to suit the cables you have and/or make up or get new cables made as needed. |
Control|24 and ProControl with Pro Tools 11? | xStix99x | ProControl, Control|24, Command|8 | 2211 | 04-29-2019 01:23 PM |
ProControl in Pro Tools 9 | BejankaMop | ProControl, Control|24, Command|8 | 5 | 11-12-2012 01:31 PM |
pro tools hd 9 and procontrol | djgusmusic | macOS | 0 | 07-10-2012 09:11 AM |
Pro Tools HD2 8.1-9.0 using ProControl | jpd52 | Pro Tools TDM Systems (Mac) | 0 | 01-22-2011 06:37 PM |
ProControl working with Pro Tools 9 | brdst | Post - Surround - Video | 1 | 11-08-2010 02:49 PM |
