Old 11-21-2019, 08:22 AM
mixedbyfabian mixedbyfabian is offline
Default Can anyone help? Protools stuck on offline bounce
Hey guys im new here so I apologize if I'm posting wrong or in wrong forum. Im having the most frustrating issues with my system. I guess ill start with the specs
MacBook Pro (15-inch, 2019)
2.4 GHz Intel Core i9
32 GB 2400 MHz DDR4
OS 10.14.5
Im running protools
2019.10.0
with thunderbolt magma chassis
Express box 3t
with my hdx card in it
connected to two hd I/o's
So its not every session and its not all the time. basically a session will work fine then it won't. If I reboot or trash prefs it doesn't seem to change the outcome. the session may work again it may not.
Avid support told me to remove a certain plug in which I tried and it still happens. It seemed to help when I committed all the tracks then bounced but again it happens after a bit.
This weekend I traveled and I had to do some work while I was gone. I opened a few of the same sessions (that I was having issues with in my studio with hdx as playback) on the same laptop using the internal speakers or headphones and they work fine no issues at all. So its obvious at this point its something on the hdx side.
Its worth noting that this is offline bounce related online.The same sessions that I have an issue with work fine online bounce no matter what the environment. Any ideas guys?????
Old 11-21-2019, 09:12 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Can anyone help? Protools stuck on offline bounce
Hi, welcome to the community.
So what exactly is happening? You have a session which you can bounce realtime but cannot bounce offline, right?
Janne
Old 11-21-2019, 09:15 AM
hey thank you. Yeah it gets caught at the end of the bounce then protools freezes and stops responding. I have to force quit. Only happens in offline bounce. If I do online it works fine. But its not the same session every time. Also when I went to protools aggregate instead for he hdx the same session with the issue works fine
Old 11-26-2019, 11:14 AM
yes it isn't related to one particular session. sometimes it happens sometimes it doesn't. Online works fine but offline gets hung up at end then I have to force quit. this only happens with hdx playback engine. I'm not having this issue with the playback as aggregate or internal etc
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 04:55 PM
Newbie Alert ! Control 24 stuck in Offline Tracii ProControl, Control|24, Command|8 14 03-08-2015 10:00 AM
Protools 11 with Waves crashing on offline bounce StefB Pro Tools 11 5 02-16-2015 09:35 AM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 06:58 PM
Elastic Properties Stuck? --pre bounce vs. post bounce alithomas66 Pro Tools 9 2 02-07-2012 06:56 PM
