Old 11-06-2019, 03:36 PM
Mark Frith Mark Frith is offline
Default Digidesign 96io with Avid Omni?
I'm pretty sure it's possible to hang a digi192 interface on the legacy port of the avid omni, but is this also the case with the 96io? I don't see why not but I need to know for certain...is anyone working this setup?
sorry if the answer is already here somewhere - I can't find it.
Thanks M
Old 11-06-2019, 04:06 PM
Default Re: Digidesign 96io with Avid Omni?
Actually maybe it needs to go on the 2nd port of the hdx card..?
Old 11-06-2019, 10:11 PM
JFreak's Avatar
JFreak JFreak is offline
You can connect to 2nd digilink of the card, or you can daisy-chain it with the first one. The only restriction is you cannot have more than one OMNI but other HD interfaces can be mixed as you wish.
"LEGACY" port is for MIX era black interfaces.
Janne
Old 11-06-2019, 10:54 PM
Awesome, thanks. M
Old 11-07-2019, 12:09 AM
JFreak's Avatar
No problem.
Have to add that the Legacy Port might not work on current Avid-branded PT software any longer, but at least it did with DigiDesign (pre-9) versions. In that case, when you selected Legacy port from hardware setup, the wordclock i/o (normally standard 1x clock) begins to feed 256x superclock needed for MIX interfaces. And obviously you are limited to 48k max.
Janne
Digidesign 96io Interface dexter808 Buy & Sell 0 03-24-2016 02:28 PM
Digidesign 96io Loudnoize Ent. Buy & Sell 4 03-13-2015 02:31 AM
FS: Digidesign 96io TXDigi Buy & Sell 0 01-29-2014 10:06 AM
FS: Pro Tools HD3 PCIe + Digidesign 96io Mihael Hercog Buy & Sell 1 12-21-2013 10:44 PM
Digidesign 96IO Connections jerberson12 Pro Tools TDM Systems (Win) 0 07-10-2012 03:36 PM
