Old 03-17-2013, 03:27 PM
bobmiz bobmiz is offline
Default 7.x backward compatibility issue with 6.4
Up-graded from 6.4 to LE 7.0. 6.4 sessions open but part of the way thru the tracks, DAE error 87 appears and the error message about "DAE can't get audio fast enough....(-9073)" Any known fixes for this one ?
Thanks
PT 7.0 Digi 002
Gateway w/ P4 2.8 Ghz
XP Home SP1
2.5 Dram -
Glyph Net drive 7200 Rpm
Old 03-18-2013, 07:02 PM
Default Re: 7.x backward compatibility issue with 6.4
You probably should post a Sandra report as described here: Help us Help You - READ THIS Before Posting!
And tell us what interface you have too. Considering how NOT powerful a P4 is, with 2.5GB of RAM, and I have no idea what this is: "2.5 Dram - Net drive", this computer may not be up to the task. PT 7 changed the way the software interacts with the cpu(allowing for multi-core use) and each major upgrade(7, 8, 9, 10) requires more power from the computer(for all the extra features and functions).
One thing you can try is; create a new blank session and then use the Import Session Data function and import everything from the old session.
Old 03-20-2013, 12:18 PM
Thanks albee:
I tried your suggestion. "create a new blank session and then use the Import Session Data function..." I can import pt6 wav files but not session data. And those are 2 ch. Sometimes the p6 sessions will play for 30 - 45 seconds and hang. Other than that, pt7 sessions runs fast and smooth. no prob.Btw I use a 002 interface, external Glyph Net Drive 115GB @ 7200 Rpm.
Peace....Robert
PT 7.0 Digi 002
XP Home SP1
2.5 Dram -
Backward Compatibility with PT8 to PT7 ecovindaloo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-06-2009 10:06 AM
PT 7.4 backward compatibility Tom Stoeckel Pro Tools M-Powered (Mac) 3 11-21-2007 12:32 AM
Backward Compatibility Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-03-2004 03:33 PM
Backward compatibility of HD ^Tripper^ Pro Tools TDM Systems (Mac) 9 03-18-2002 01:34 AM
Backward compatibility of HD ^Tripper^ Pro Tools TDM Systems (Mac) 0 03-13-2002 08:59 PM
