Old 03-06-2013, 07:04 PM
mudlake slim mudlake slim is offline
Default Can't Find Hardware after xp/win7 upgrade
I had to upgrade from windows xp to windows 7 and now I'm trying to install Pro Tools M-Audio 8.0. I got a link to the 8.04 update from Avid and then I used the 8.05 updater. Everything seems fine until during startup I get the message that my hardware can't be found and to make sure it is connected and powered up. I'm using Fast Track USB. My Fast Track driver is current. Any ideas on how to make Pro Tools see the Fast Track USB?
Thanks in advance.
Old 03-07-2013, 05:58 AM
Default Re: Can't Find Hardware after xp/win7 upgrade-solved
Problem solved...finally. I needed to install driver software from Fast Track USB. I was able to find this on the Avid site and once the driver software was installed Pro Tools 8.05 was able to detect it.
Can't find hardware TC Konnekt 48 PT9.03 Win7 32 Sofine Windows 3 08-24-2012 08:39 AM
Can't Find Waves 7 PT9 Win7 64 DonM Windows 3 03-23-2011 02:24 PM
Any performance difference between PT8/XP & PT9/Win7 32-bit on same hardware? mlemos Pro Tools 9 8 12-07-2010 02:44 PM
Can't find hardware with upgrade version Tim Krukowski Pro Tools 9 3 11-04-2010 11:20 PM
what pc hardware should I buy for PT HD2 Pci-e with win7 64bit KKalampo Pro Tools TDM Systems (Win) 0 08-14-2010 11:46 AM
