Old 03-19-2010, 07:04 AM
RichrdC RichrdC is offline
Default Changing Pitch of MIDI
I'm running MP 8.0.3 and love it. I'm playin' around with the Elastic Pitch capability, and it's great. It certainly works on audio tracks, but it doesn't do anything for MIDI tracks. Can someone direct me on how I can change the pitch of MIDI data.. How would I raise violins say, 4 semitones? Do I have to actually drag each note up the scale? I hope there's an easier way of doing it, other than just recording the track over.. Thanks for any insights.. Richrdc
Old 03-19-2010, 07:13 AM
scenicrecords scenicrecords is offline
Default Re: Changing Pitch of MIDI
Choose Event->Midi Real Time Properties. Select a Region of MIDI data and use Transpose to move your notes up or down, then Write to Region if you are happy with the result.
You should read Chapter 29: Midi Editing in the Pro Tools Resource Guide for detailed information on the many ways you can edit MIDI in Pro Tools.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 03-19-2010, 09:13 AM
Chapter 29... thanks so much for the instructions and directions... take care
Old 12-21-2011, 01:58 PM
midifirst midifirst is offline
I'm really surprised that there doesn't seem to be a single key command to raise or lower the pitch of a note in the midi editor.
Please let me know if I'm wrong about this.
Old 12-21-2011, 02:14 PM
anothercolour anothercolour is offline
In the tracks Playlist selector, be sure the MIDI track is set to Pitched.
Then, insert key changes in the Keys Conductor ruler.
cneal92's Avatar
cneal92 cneal92 is offline
Event > Event Operations > Transpose (Opt-T for Mac).
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: [email protected]
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 12-21-2011, 06:32 PM
Thanks for the previous replies.
Re my previous post;
I'm not sure if it was understood that I was hoping to change the pitch of a midi note with literally a "single Keyboard" command, .i.e. in a fraction of a second.
I didn't want to have to use the mouse at all. An example of how this might be implemented would be to have say, "OPTION COMMAND UP ARROW/DOWN ARROW" raise/lower a note one semitone.
(In Logic option UP/ DOWN Arrow raises/lowers the pitch of a midi note on semitone.)
Old 02-26-2012, 08:55 AM
Pieterrr Pieterrr is offline
i'm curious to hear that answer! i've used logic too, and so far i'm missing that option in protools.
Old 02-26-2012, 10:08 AM
cneal92's Avatar
You can nudge MIDI notes by semi-tones using Control (mac) and -\+ on the numeric keypad.
Old 02-26-2012, 12:08 PM
thanks!!!
midi editor - changing selected notes to the same pitch.... mafiacondon Pro Tools TDM Systems (Mac) 1 05-25-2011 05:11 PM
changing tempo without changing pitch Sharabelle Pro Tools TDM Systems (Mac) 3 02-10-2007 05:19 PM
Changing Pitch of incoming midi bubbiesdod Pro Tools M-Powered (Win) 0 10-18-2006 11:15 AM
Changing Pitch Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-02-2004 08:31 AM
changing the MIDI pitch from A440... keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-24-2004 07:25 AM
