Old 11-16-2007, 12:04 AM
One Track Music One Track Music is offline
Default Which Surround Monitor Controller...?
... would you recommend. I've been using the SPL but am not totally thrilled. It's a bit clunky & big on my desk, doesn't have talkback, has already bust a channel once. Been looking at the C|24 but it's a bit overkill as I'm a composer... would love to have just its master section! I love the grace 906, but not sure why I would need any onboard d/a converters. I do need at least 2 stereo ins, which the coleman doesn't seem to have. Also posted this in the Post section.
Any thoughts would be greatly appreciated.
Thanks so much!
Joel
www.joeldouek.com
"Show me your Pasodoble!"
Old 11-16-2007, 01:16 AM
asm's Avatar
asm asm is offline
Default Re: Which Surround Monitor Controller...?
Hi Joel,
I have been using the Grace m906 for the past 2 years and it is a great monitor system. I have a 192 connected digitally to the AES surround and AES stereo 1 + 2 inputs, through a digital patchbay. This allows me to route the outputs of my pro tools session or any of the other devices on the patchbay (e.g. Tascam DVR recorder, external stereo AD converters) to the m906 inputs. The DA converters on the m906 are excellent, as is the stepped volume control, headphone output, talkback mic preamp, etc.
The unbalanced surround inputs are incredibly useful for listening to reference mixes from my consumer dvd-a/sacd player on both the surround and stereo outputs. I also use the cue i/o in between the pro tools headphone mix out and the studio cue system so that I can inject talkback into the headphone mix, or easily redirect any of the inputs to the studio headphones. The extra s/pdif and toslink digital inputs are connected to my cd player + apple computer optical digital output. In this way, any reference audio, whether cd, mp3, internet audio, software other than pro tools, etc. is output through the same DA converters as my pro tools mix. I also have an analog mixer feeding the balanced stereo input. A simple press of the button allows me to switch between any of these sources monitored through the same signal path.
IHTH
Andrew
Andrew Mittelman
www.soundgeneration.net
Old 11-16-2007, 09:21 AM
Thanks so much Andrew, that's awesome info. You'll never believe this... I went to your website & saw my address, confused I realized I'm in the studio just 2 floors above you!! I'm in 503. Perhaps I could stop by & have a little look/chat?
All the best,
Joel
www.joeldouek.com
Old 11-16-2007, 09:40 AM
One more question Andrew: using the optical ins for the Apple, can you monitor the input simultaneously while working in PT? I currently route the Apple outs into a spare slot on an interface, and can then hear it through an aux within sessions... usually for iChat or iTunes.
Thanks!
Joel
www.joeldouek.com
Thanks!
Joel
www.joeldouek.com
Old 11-16-2007, 12:43 PM
asm's Avatar
asm asm is offline
Hi Joel,
That is funny - typical of New York that we work in the same (relatively small) building and meet on the internet. I use the optical input on the m906 so that I can switch inputs while PT is running. The other advantage of the m906 DA converter is that it accepts all incoming sample rates without having to slave to one particular clock. So the cd player @ 44.1k, computer @44.1k, PT @ 48k sample rates works fine.
I will send you a pm.
Cheers
Andrew Mittelman
Old 11-16-2007, 12:58 PM
doug kaufman doug kaufman is offline
Gotta put in my vote for the Dangerous Monitor SR - works and sounds great...and looks like it was pulled from the Starship Enterprise.
dpkaufman.com
Old 11-16-2007, 03:17 PM
Mmmm Star Trek! Pretty seductive there. I just read this on the Dangerous website about their monitor. This is HYSTERICAL!
"The PPI (or “Producer Pacification Indicator”) button is likely to save your mixes as well. It doesn’t do anything (except when in Setup mode,) but the next time you have a perfect mix together and a producer says, “I like it, but it just needs a little more,” you’re covered. When this happens, simply pop on the insanely cool blue PPI light and say “Which do you like better, this (off) or this (on)?” Invariably, the producer will pick the “blue light” setting and you can happily print your mix, collect your fee, and move on to your next job".
www.joeldouek.com
Old 11-18-2007, 01:48 AM
Michael James Michael James is offline
+1 for Dangerous ST/SR. The feature set is comprehensive, and the sound is excellent.
Michael James
michaeljamesproducer.com
www.IndieProMix.com
System info: PT Ultimate 2019.6 HDX, Mac Pro 5,1 Westmere, OS 10.13.3, UAD2 Octo PCIe, 2x Lynx Aurora16 w LTHD cards, 1x Lynx Aurora(n) 32 ch analog I/O DigiLink, 4x Dangerous Convert-8 (AES via Lynx), Dangerous Convert-2 (AES via Lynx), Dangerous Vonvert AD+, Apogee Big Ben, SSD boot drive, external FW800 audio drives
Old 11-18-2007, 05:43 PM
Yup in the end I think the price of the Grace is a bit steep for my needs, and I've now fallen in love with the coloured lights and remote of the Dangerous one. I've decided to go with that. I also like the modular expandability of it. Some very cool possible additions that it seems were shown at AES...
http://aes.harmony-central.com/123AE.../Expander.html
Thanks all for input. Much appreciated.
Joel
www.joeldouek.com
FS: SPL 2489 - Surround Monitor Controller SmartGear Buy & Sell 1 10-26-2013 01:34 AM
Surround monitor controller Really necessary? simonyeah Post - Surround - Video 19 11-15-2012 01:17 PM
HD 192/Surround Monitor Controller hum_uk Post - Surround - Video 5 03-26-2008 09:41 PM
Which Surround Monitor Controller... One Track Music Post - Surround - Video 17 11-21-2007 03:39 PM
Surround Monitor/ Controller meathman Post - Surround - Video 4 10-13-2007 05:51 PM
