Clipping the master track
I read somewhere that when bouncing, the master track level should not reach the red zone. I cant hear any clipping when this happen but maybe there is a good reason to avoid it. Does anyone know? If it has to be avoided, can I just lower the master track fader or do I have to lower the other tracks?
Re: Clipping the master track
I had a similar question about entering the red zone. The response was that the red will appear after 3 or so samples rise above 0 dB. This does not necessarily mean you can hear any problem, but the signal is distorted in some small way. I have tried many versions of mixes where I have surpassed 0 dB in a small way and compared it to the same mix where it does not clip the red. I have never been able to actually hear a problem with the mix unless I purposely crank the master or track levels to high excesses of red. Normally I will have one or two spots in a mix that momentarily exceed the 0 dB threshold. If you can't hear distortion that doesn't mean its not there, but it might happen over a period of 3/48,000 of a seconds at a frequency you can't distinguish from the rest of the mix frequency content.
Master track clipping? | ebonyles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 02-07-2012 11:29 AM |
Master Fader clipping | Von_Dingle | Pro Tools 9 | 4 | 10-24-2011 11:47 AM |
Master Fader Clipping | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-12-2006 01:44 PM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
