What's the difference between clip gain and volume automation on audio?
Okay so I would like to make some parts of my audio a little louder. I know that automating both the volume bar, as well as the clip gain makes it louder. My question is like what applications do you use clip gain for, and what applications do you use volume for? I;m just wondering what the best option is to make audio louder.
Think of clip gain as a pre insert volume control. I use it to set the track to be relatively level the whole way through. This makes sure it's hitting the compressor (and any other effects) at a consistent level. Then I use the fader to do the actual mixing and dynamic changes.
But it can probably be used lots of other ways also. That's just my main use.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Re: What's the difference between clip gain and volume automation on audio?
Clip Gain = Pre-insert
Volume Automation = Post-Insert Clip gain rocks for bringing up quiet parts so they hit with the same level to run though the insert processors. Volume automation is better for bring up/down passages in comparison to the mix. Otherwise your clip gain increase might hit the compressor harder than other parts, killing the transient, or adding to much clipping to the distortion it's running though. Just make sure you pull back one of the nodes if there are two layered over each other vertically, otherwise there will be an audible pop sound. They must ramp, even if it's only a very steep ramp. Hopefully they'll fix that in a future update. |
if it helps think of Clip Gain as the Mic/Line gain knob on a console
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Would it have been wrong for Avid to name and refer to Clip Gain as "Clip Volume", or does it also adjust the dynamics above and beyond what a normal volume knob would do?
I've been trying to digest the differences other than what's already been mentioned and information based on a video tutorial at the Pro Tools Expert site by Russ, IIRC. I think the video is behind a curtain, but it's called "Mixing Basics - Levels" and a little ways down page 4 right now on the production tips. http://www.pro-tools-expert.com/prod...?currentPage=4 In the video, he adjusts the levels in the Edit window and refers to it as "Gain". I was wondeering if any signal breakup was gotten from just from the volume being turned way up or if the Clip Gain functionality does some additional tone coloring of it's own? Or, is it simply a pre-insert volume adjustment? |
you can have passive level attenuation you can not have passive energy increase
However in an amp increasing the level until it clips is usually desirable (and the intention on any amp/channel designed for a distorted sound) but you (typically) don't want to clip a mixer/preamp. The exception is some tube/color preamps that do add warmth as they're pushed. Pro Tools is digital and digital clipping is almost always undesirable. So in pro tools you (typically) want your levels to be in the upper end of green with the peaks maybe bumping the yellow before any processing. So you can use clip gain to achieve that if something was tracked at the wrong level. Basically like turning a gain knob on a mixer up or down. The cool thing is you can split a track up and easily gain match large dynamic changes. For example a bass player who played too softly during an intro, or a drummer who was killing the snare during the bridge.
Yes, guitar player first and foremost.
Thanks for the answers, folks. I think that clears things up for me. I've not been using the Clip Gain functionality to it's fullest extent. This adds a bit to the tool-box. |
Clip gain or Volume Automation for S's on Vicals | SpinningDisk | Tips & Tricks | 12 | 12-20-2013 06:52 AM |
So has clip gain replaced automation for ya? | acmost | Pro Tools 10 | 11 | 05-13-2012 07:22 AM |
Clip Gain and volume autiomation | bonzerboy | Pro Tools 10 | 3 | 05-07-2012 11:52 AM |
Clip-gain post-EQ but pre-volume-graph? | Frank Kruse | Post - Surround - Video | 11 | 11-29-2011 10:18 AM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
