Avid: Can we please have an option to "disable HDX engine"?
I recently "upgraded" my HD|Native system to an HDX card, and aside from it being a complete waste of money with so little AAX-DSP plugins available, the fact that I can't open sessions that worked absolutely fine on my HD|Native card is an ABSOLUTE JOKE.
128 voices at 96k doesn't go very far on a HDX system, that's for sure. Avid.. please give us a way around the fact that a HDX rig is somehow more limited than a HD|Native when it comes to "Voices"?! So far, HDX has been a total waste of a whole lot of money.
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix 2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1 SSL 4056G |
Re: Avid: Can we please have an option to "disable HDX engine"?
If you don't select HDX as your playback in MAC / PREFS / SOUND .
PTHD opens as just PT with CPTK capabilities . Which really is HDN So you have what you want already . How is HDX any less than native . It is native with DSP to . Could you explain why using native plugs in HDX yields any less of a result. I have a session that is at 75 80% native and 50% of a HDX card at 32/96 . Somehow I don't see how HDN could do better with out the DSP. I do agree on the plugin problem but at least you knew that going in , AS HDX PRE PAYERS WE DID NOT . |
After reading a older thread of mine I came across this .
[QUOTE=ilovemyssl That sounds a little odd.. I've mixed some big projects over the past few months with PT10HD and just a Native card with no problem... 100+ tracks with anywhere from 4 to 10 plugins per track plus tons of bus sends. I just upgraded to HDX last week and the same sessions seem to be opening fine. What Sample Rate are you working at? [QUOTE] Are you following the NATIVE / DSP rule. Or the native on aux track deductions. Use VCAs when possible I have recently found out that VCAs can save on voice count. I do not use as many aux busses now unless I absolutely have to |
Can't import video "Avid engine not installed"??? | garnoil | Post - Surround - Video | 9 | 10-08-2012 04:45 PM |
Those getting "audio tracks stop playback/outputs disable" Questions? | crizdee | macOS | 15 | 09-25-2012 08:10 AM |
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init | bcrichguitar | macOS | 3 | 04-01-2012 09:10 AM |
"Avid Video Engine Not Installed" | trondned | Post - Surround - Video | 9 | 09-17-2009 02:43 PM |
disable usb with digi 001 factory?? "davec test" not great with AMD XP 1700 | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-28-2002 04:33 PM |
