installed with a different mbox, does not work?
I have pro tools 8 LE with an Mbox2 at home installed on my regular computer.
I went to a friend with my laptop, and he installed pro tools 8 LE with his Mbox 2 pro, and we set it up so it worked on my laptop. Now I got back home, and wanted to start up a session using my laptop (that was originally installed with my friends Mbox 2 pro) using my own Mbox2, but it does not seem to work. Is every installation bound to be used with only one specific Mbox hardware? Is there a way to make his installation on my laptop work with my regular Mbox2 unit? |
Re: installed with a different mbox, does not work?
shouldnt be,iv used mine with another mbox
Was it the same type of Mbox? My friend has an Mbox 2 Pro, meanwhile my own is a regular Mbox2. |
The software is not tied to any particular hardware, unless that version no longer supports it (original M-Box with PTLE 8.0.3+ for instance).
Your version of PTLE for both installs?
Learn to listen. Listen to learn. |
8.0.3cs2 on both installs |
Maybe you need to define "doesn't work". Do you mean the software refuses to open? Or that sessions open but you don't hear anything? Have you tried resetting your IO?
I tried it once again, same thing again, i forced quit after 1 min. A third time, pro tools even stopped loading half way through the plugins, and once again the colored ball showed up. |
MBox 2 USB: Max Audio Quality - 48khz 24Bit
MBox 2 Pro Firewire: Max Audio Quality - 96khz 24Bit You can't open 96khz sessions with an Mbox 2 USB
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
Pretty easy to get around, too. Create a new session at 48 or 44.1, Import Session Data from the higher session. Done.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
If it is failing at the plugins, do you have any 3rd party ones that could be causing problems?
installed pt 10 demo, mbox 2 wont work | bbchoke | Pro Tools 10 | 1 | 04-07-2012 02:04 PM |
mbox 2. Installed protools 8, now cubase won't work | gulagurk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-30-2011 04:41 PM |
Just installed 6.7 and now Command 8 doesn't work? | cc1 | Pro Tools TDM Systems (Mac) | 4 | 11-01-2004 03:10 PM |
DH-Max doesn't work since i installed... | tomcat | Pro Tools TDM Systems (Mac) | 3 | 01-18-2002 07:47 PM |
DH-Max doesn't work since i installed... | tomcat | Pro Tools TDM Systems (Mac) | 0 | 01-18-2002 01:25 PM |
