Old 04-06-2010, 01:50 PM
DigitalMetal DigitalMetal is offline
Default Anyone know if this applies to Mix hardware on PT 6.4.1 ?
this artilce in the avid FAQ section:
http://avid.custkb.com/avid/com.instranet.InstraServlet?Command=com.instranet. CmdDocVote&Redirect=/avid/app/selfservice/search.jsp&DocId=208065&UEL_DocVote_DocId=208065&U EL_DocVote_Rating=1&UEL_DocVote_VotedDocExtIds=&Mo dule=selfservice
Does Pro Tools TDM 6.4 and higher compensate for sample delay in RTAS plug-ins?[208065]
RTAS Plug-Ins fall into two categories: Most RTAS Plug-In reports 0 samples of delay. In this case, since the input to RTAS plug-ins is an audio track (rather than an aux track), we pre-process the audio before we play it out. So, you get RTAS processing with no apparent sample delay. There are some RTAS plug-ins that report > 0 samples of delay; Maxim is a great example. If you insert an RTAS Maxim you'll notice that it reports 1024 samples of delay. In this case, Pro Tools will adjust for the HW BUffer Size processing delay, and AutoDelay Compensation will adjust for the reported plug-in delay.
Does this apply to Mix systems?
I know HD has PDC but im running PT 6.4.1 on mix and this says 6.4 or higher,
PT10HD5 PCIX in 64Bit Magma Chassis,
2x192io's + 2x96io's & Legacy io's
Pro Control & Fader Pack
UAD2 Quad, Octo & All Plugins
Black Lion Audio Modified MOTU 24io and 2408MK3 x2
TC Powercore PCI MK2 x2 & Firewire
Softube, Sonnox, Eventide, SSL, McDSP, Waves
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Edit Applies to All Playlists . . priorytools Pro Tools 9 2 05-30-2011 02:57 AM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
