HDD arrangement - System+Scratch+Samples?
Hi guys I have a quick question about the correct way to setup my system. I thought I had an understanding of this but I'm finding myself a bit confused in some areas. I tried to search around but couldn't find an answer so I apologies if it is already out there.
So basically I understand that it's common practice to have two separate hard-drives. One for the system/DAW and the other as the scratch drive. I am using a 13" 2.53Ghz Macbook Pro and I have a FW800 Lacie as my scratch drive. I use pro tools 8 which is installed onto the internal system drive. I also use drum sampling software like BFD, Superior 2.0 and Battery. My question is...Should these samples libraries be located on: 1. The system drive, 2. The scratch drive, or 3. A third dedicated hard drive? And also should the programs themselves be installed on the external drive/s or just the library content? Hope that makes sense. Thanks in advance for your help. Cheers. |
Re: HDD arrangement - System+Scratch+Samples?
Good general rule of thumb, no matter the daw software: programs on a fast system drive (PT doesn't support recording to the system drive), samples (if you use them a lot) on a second drive, and recorded material on a third drive. And I'm talking distinct drives, not partitioned drives which don't get you anything.
Thanks for that. I currently have PT on my system drive which is stock standard (thinking of replacing it with a SSD) I have a LaCie FW800 external for my audio and I have my drum sample libraries on a third USB2.0 drive.
Equipment Arrangement ??? | TheFuture4 | MIDI | 1 | 03-05-2012 09:24 PM |
Window arrangement? | Creap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-27-2010 11:26 PM |
Question About Two Drives vs. Three (System, Audio, Samples). | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-11-2009 04:52 PM |
Forum arrangement... | flommer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-21-2009 01:26 AM |
My whole system crash when i set my H/W Buffer Size @ 128 Samples or less | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-29-2002 02:50 AM |
