  #21
Old 03-23-2010, 09:57 AM
smpkeys smpkeys is offline
Default Re: DAE Error -9019 & -9031 since PT 8.0.3
Happened to me again yesterday. I was copying a short vocal part from one playlist, and when I switched playlists, it happened. For me, it seems to be consistent with switching playlists. I had "smack" active on the track, and
auto tune and melodyne were also on the track, but inactive.
Digi - any luck yet with this problem? I'm zipping my log file and sending it.
thanks
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
  #22
Old 03-23-2010, 06:54 PM
and yet again it happened an hour ago. This time , all I did was open a session, walk away for a few minuets, then I pressed the space bar to play the song and it did this.
I'm going to try tonight to backup my audio drive, and re-format it.
When I search the DUC for these errors, it's mostly people using Windows.
I wonder why I'm getting these since I'm on a Mac?
  #23
Old 03-23-2010, 11:27 PM
Originally Posted by DigiTechSupt View Post
Your Pro Tools Reference Guide has a list of unsupported characters. You should make sure that no drive, folder or file name contains any of those characters.
This error on Mac is also caused by incorrect drive format. I would recommend backing up your audio/video drives and erasing them using the Disk Utility, then copy the data back and test again.
Just to verify, the correct way to format a mac audio drive is:
Mac OS Extended (Journaled) , correct?
thanks
  #24
Old 04-28-2010, 04:16 AM
yuras77 yuras77 is offline
"Delete Pro Tools preferences" in "General Troubleshooting" has solved this error.
It's been 3 days after that and it works perfectly! Good luck to everyone!
  #25
Old 04-28-2010, 10:19 AM
billscores billscores is offline
Add me to the list. I've experienced 10 - 12 of these over the last five days.
Error 9019 followed by error 9031. Happens randomly after hitting spacebar for playback. Must quit ProTools to resume.
Mac quad core 3.0 gHz, 10.5.8
ProTools HD 3 -- ver. 8.0.3cs2
all internal SATAs
Never saw this error before this week or before 8.0.3cs2. It's happened in three different sessions so far and getting very agitating.
I went as far as saving my current session and sample libraries (Stylus and Battery) to a new, freshly formatted drive.
It didn't help. I'm going to trash my preferences and see if that helps.
I love trashing my preferences... I now keep a sticky note on my monitor with a list of the 30 or so things I have to reset every time. It's so much fun, you guys should try it.
  #26
Old 04-28-2010, 10:26 AM
reichman's Avatar
reichman reichman is offline
Listen, I want to hear from someone who is getting this problem, and is NOT using SATA or eSATA. I get the error once every 2-3 days, so I haven't been terribly motivated to figure out why. Is someone on Firewire seeing this? I use eSATA, and I want to eliminate it.
Best,
Nathaniel Reichman
www.nathanielreichman.com
MacPro 2.8Ghz 8-core, 6GB RAM, 10.5.8, Pro Tools LE 8.0.3cs2 with Complete Production Toolkit, Quicktime 7.6.4, Digi 002R, Control|24, Blackmagic Intensity Pro, eSATA hotswap tower, Baby HUI, Soundminer 4, Waves Platinum 6, Audio Ease All-In, Melodyne, SoundToys, Izotope RX, GRM Tools, PSP, Retrospect...
  #27
Old 04-30-2010, 09:25 PM
ZEUSS ZEUSS is offline
Whats going on here??? Tired of this. Worked on another rig with 8.01 for a month and never got this. Studio tech asks if I want them to upgrade to 8.03. I say no way. I tell him I would be trading the 8.01 bugs for the 9031 errors etc. Show stopper!!! Vibe killer!!!
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
  #28
Old 05-01-2010, 02:08 PM
Oroz Oroz is offline
Found the culprit in my case. I checked every plug-in and found that an my version of DFHS is not compatible with 8.0.3. I removed it and it's working great now. I'll have to upgrade to Superior Drummer to be able to use that plug-in.
  #29
Old 05-05-2010, 04:37 PM
it wasn't that. It's still doing it. Gonna check every plug-in again.
  #30
Old 05-20-2010, 07:59 PM
Reesho Reesho is offline
This started happening to me when I started using samples via Structure and other instruments. I normally use only audio and BFD2 samples on another drive. I realized that I had my audio drives partitioned into two, one for audio and one for samples. (smack my forhead-DUH!) Today I copied all my data to an external, reformatted the drives to one partition so that my samples are on a separate drive from the audio. I also moved the Pro Tools Creative Collection (with Structure, Boom, Mini Grand etc.) off the Applications drive (where they installed themselves by default) and onto the samples drive. So far I haven't gotten the errors again within the time frame I was getting them.
So if you don't hear from me again in this thread it's a done deal. For me it was definitely the cross data accessing between the audio and the samples or the applications and samples on the same drive. I only hope my elation isn't premature.
Mac Pro 2x3.46 Ghz Dual 6-Core Intel Xeon
64 GB Ram
OSX High Sierra 10.13.6
PTLE Subscription - pending
Interface - pending
Midi Controller =M-Audio Axiom 49/USB2
HTML code is On
Dae error 9019/9031 shaunandrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 04-10-2011 12:38 PM
Error -9019 and -9031 henrikas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-05-2011 09:34 AM
Structure v1.1 error 9031 and 9019 insanesounds Virtual Instruments 62 03-16-2011 03:19 AM
err -9019, -9031 greetings to Digidesign. sotger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2010 06:23 AM
DAE Error 9031, 9019, 9073 on Pro tools M-powered rico1234 Pro Tools M-Powered (Win) 0 12-12-2009 12:28 PM
