PTLE w/ Mac Pro - Internal SATA drive order?
Problem -
PTLE freezes temporarily while using Ocean Way Drums located on an internal SATA drive. PTLE freezes temporarily when saving a session using Ocean Way Drums. I am wondering if the order of the SATA drives is at all important. Mine are - 1. system 2. samples 3. PT sessions/audio Any suggestions?
Recording # Editing # Mixing # Mastering SALMON SOUND Studio # Mobile # Online http://www.salmonsound.com |
Re: PTLE w/ Mac Pro - Internal SATA drive order?
Ocean Way Drums runs via Kontakt right?
Kontakt it not yet up-to-date for Leopard and PTLE 7.4.2. Maybe in December when NI releases Kontakt 3.5 there will be some more stability, but until then I'd be willing to bet that's the reason behind your problem. And/Or.... looking at your system specs, you have some problems in there too. You're running Mac OS 10.4.7 with PTLE 7.4.2? Those don't really go together... |
os 10.4.11 ptle 7.4 kontakt 2.2.4 still, is there a correct order in which my drives should be mounted?
No, drive order doesn't matter. You should however have spotlight turned off etc. as covered in the General Troubleshooting thread.
if you are running 7.4 you might want to step up to Leopard.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
ProTools Boot drive migration to a new internal SATA drive | audiowave | Pro Tools TDM Systems (Mac) | 1 | 05-03-2011 03:45 PM |
External Glyph or Internal SATA drive? | DeyBwah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 03-09-2010 05:56 PM |
PTLE 6.9.2 + new SATA internal gives me a -5000 error. HELP! | neil_mcdermott | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-12-2007 03:43 PM |
Another Firewire Drive or Internal SATA II Drive??? | fenderguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-14-2007 01:44 PM |
External Drive writing to Internal SATA Drive | Teen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-16-2007 07:29 AM |
