Old 03-17-2003, 01:04 AM
Carbon111 Carbon111 is offline
Default Mix TDM on Intel 845?
Currently I'm running my Mix core on an old BX mobo with a PIII-500. I'd like to bring my system out of the stone age with a very quiet Intel845 running a P4-2ghz with 512mb of DDR ram. The compato docs suggest this is doable... Any negatives or "gotchas" I should watch out for? Thanks!
Old 03-17-2003, 02:43 AM
NIAFRON NIAFRON is offline
Default Re: Mix TDM on Intel 845?
hi,
I work with 1 PT24 and 1 PT24Mix on ASUS P4PE (i845PE chipset), Pentium 2.8Ghz with DDR 512 (PC2100) and It work wery well. Each configuration have 2 HHD ATA IDE (one for the system, one for audio). 32 tracks avabled on PT24, 64 tracks on PT24Mix. No Problem detected on with Protools Version 5.3.1.( I have open up to 250 RTAS plugs on the same session just for fun!)
[img]images/icons/tongue.gif[/img]
Old 03-19-2003, 08:27 AM
Dave Lang Dave Lang is offline
My reading of the compatibility documents suggest that the Intel 845 is not supported.
Check the url here:
http://www.digidesign.com/compato/pt24perfwin.html
They recommend an Intel 850 or 860 chipset.
Having said that, I run a PT Mix w/5.3.1 for XP on a Gigabyte 8IEXP that uses the Intel 845E chipset with no problems.
ymmv
dave
Old 03-20-2003, 01:04 PM
nukmusic nukmusic is offline
Maybe checking here may help got on idea: web page
Docta'J
Download free music at
http://www.nukmusic.com
nEVER uNDERESTIMATE kNOWLEDGE
Old 03-20-2003, 05:22 PM
Dale-c Dale-c is offline
I have installed my Mbox on a PC that I built where I work that sounds just like what you are describing and it worked fine. I will say that I haven't used it much since I have a Mac for Pro Tools, but I think that you should be fine. It is an 845xxx with 512DDR.
I'd say go for it.
Old 03-20-2003, 08:35 PM
mBox and TDM are vastly different animals...the Mix Core is very tempramental.
Regards, James
Hard drive pre- intel, post- intel juicytunes General Discussion 10 12-11-2011 09:51 PM
RTAS plugs Intel vs non-Intel versions springthing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-27-2011 12:59 PM
Intel iMac 2.8 gHz vs. PPC quad 2.5 (non-intel) Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2008 05:56 AM
Protools doesn't start up on new MiniMac intel, Imac Intel,. Lennert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-14-2007 01:17 PM
Intel® 915P Express chipset and the Intel® Pentium darkglass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-23-2005 06:05 PM
