VST Problems in PT10
I have just updated to PT 10 and PT is freezing up whenever I try to use Musiclab RealGuitar, Real LPC, and Real Strat. Running a single midi track and one instance of the plugin. I reset the wrapper database and rewrapped them using VST to RTAS 2.1 from fxpansion. Seems to work fine with everything else and these are the only plug in I have to wrap. Any ideas what may be causing this hang? Thank you.
Re: VST Problems in PT10
really strange. I'm using them as wrapped VIs, too.Got RealGuitar & RealStrat pretty often instanciated directly into PT-sessions and I just verified - both work okay here. Did you do the usual PT-troubleshooting already ?
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
No I have not I guess that will be my next stop. I will post back what I find out.
I played around a little more with the setup and found that I just needed to adjust the settings in the playback engine. PT9 liked 14 processors at 95% PT10 likes 15 processors at 99%. I had nine different virtual instruments running with six different verbs running constantly for 2 hours without a hiccup.
Very strange problems - Need help! (OSX 10.8.5 + PT10.3.7) | heabow | macOS | 3 | 12-02-2013 05:01 AM |
002 PT8 Le move up to PT10 asking for problems? | Trainwreckmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-28-2012 06:40 PM |
003r and PT10 problems - Please help! | dom_1982 | macOS | 2 | 10-12-2012 12:41 AM |
Migrating to PT9 - Too many problems using PT10 | MadDogRunner | Windows | 0 | 05-24-2012 11:55 AM |
OT: TL Space-Problems in PT10 HD! | lownotesinc | Pro Tools TDM Systems (Mac) | 1 | 11-07-2011 10:22 PM |
