Mbox 2 Inaudible -10dB "noise" on one channel - hardware problem?
Hello all...
I have been using an MBox 2 since 2005 with no problems. Yesterday I turned it on and suddenly on Input #2 ("In 2" in ProTools), it looks as though there is a constant -10dB noise in that channel (i.e. the meter shows this noise even though I can't hear anything). This happens regardless of whether or not a mic is plugged in. It remains consistent regardless of the volume level of any of the knobs on the MBox, and remains consistent with Phantom Power on or off. Nothing I can select or change on the MBox itself affects it at all. I cannot hear anything in the channel and when I record something, the waveform looks fine, but simply displaced vertically above the center line about halfway to the top. When I play it back there is some fuzz in addition to the sound and a clear pop at the beginning and end of the track. I have tried different mics, different cables, different USB cables, different power outlets in my house, I have done all the "dumping and cleaning out" business, and I have tried it on two computers running different versions of ProTools. So I suspect it must be a hardware issue. Does anyone have any experience with this kind of problem? My MBox is surely out of warranty and free tech support. Is it worth attempting to get Digi to fix it or should I replace it? Any advice? Here's the info: MBox 2 Computer #1: 20" iMac purchased in Dec. 2008 OS 10.5.6 2 GB Ram ProTools LE V 8.0 Computer #2: 12" PowerBook G4 purchased in Sep. 2005 OS 10.4.11 512 MB Ram ProTools LE V. 7.0 Thanks! |
Re: Mbox 2 Inaudible -10dB "noise" on one channel - hardware problem?
I am having exactly the same problem, mine went down a couple of days ago, not really sure what caused it, but think it may have been a faulty microphone...
had any luck finding out what the problem is and how it can be resolved? i have found people having the same problem on various forums, but so far no luck finding a solution |
Have you tried installing the latest firmware for the Mbox 2? It may fix the problem.
This is assuming you've already trashed preferences and done a shut-down and unplugging/replugging of the Mbox 2. |
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I assume that the latest firmware for the Mbox2 is v. 1.43, correct?
Channel I/O keeps loading old I/O and not "no input"/"no output" | Arve Gotfredsen | macOS | 4 | 02-12-2013 04:38 AM |
Urgent!Mac Book Pro 10.7.4,Mbox 2 Mini can't read the any signal,only "click" noise | TongWunFung | macOS | 11 | 10-17-2012 05:35 AM |
Mbox mini installation problem - "Hardware Not Found" | tinsoldierman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2010 03:06 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
DIGI 002, Problem installing hardware driver "cannot find hardware" on install | inevitable realisation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 08-21-2003 02:03 AM |
