Old 06-04-2017, 07:24 PM
Yankeemix Yankeemix is offline
Default Keyboard Static sound issue
I have my Motif connected to the 003 Console 5/6. When I play the keys on the keyboard there is a static sound ? I also have humming sound while the keyboard is on and audio cables connected.
When the keyboard is off the humming sound is gone, however if I turn the volume way up I can hear that same static noise. If I unplug the audio cable from the console then it's gone completely.
I also have this issue with the monitor knob on the console. There is a loud static sound every time I turn the knob.
Music production: http://www.myflowbeats.com
Old 06-05-2017, 05:40 AM
Default Re: Keyboard Static sound issue
One possiblity to the humming sound is probably a ground issue - is all your equipment plugged into the same AC outlet? If not - do so. Another is the audio output on the Motif (you don't say what version you have) is an unbalanced connection and I don't know what's on the 003. If the 003 is a balanced connection that could be the issue.
As to the static sound there could be a couple of issues. One is the cables - you may need new ones. Another is iffy connections due to dirty connections. A little isopropyl alcohol and q-tips should do the job.
The sound you're hearing when you turn the knob on the 003 is due to a dirty pot. To clean that unplug the unit and open it up. Get some contact cleaner, spray it into the back of the pot and turn the pot several times. I'm making an assumption here that the pot is an analog control.
Jack
QAPLA!
Old 06-06-2017, 02:36 PM
Yes, all my equipment are plugged into the same outlet. It's the Motif XS8
Unbalanced connection from Motif to 003 5/6 - See pic. I disconnected the cable so you don't see it in the pic. https://ibb.co/cq1nfv https://ibb.co/kZwyna
Audio cables connected to the main inputs of the 003 are also unbalanced cables. - See pic
https://ibb.co/enJptF
And where would I use the Isopropyl alcohol to clean?
Old 06-07-2017, 04:05 AM
Use the IPA and q-tips to clean the contacts of the connections; you may have to take the cover off the 003 to get to them. Do this with the unit unplugged.
Jack
QAPLA!
Old 06-07-2017, 07:35 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi !
Just to let you know that when i use unbalanced audio cables from my 003 to my actve mackies monitors i get a ground always ..I have to use balance not shure why . Does not hurt trying balance cables there if you have a pair avialable .
- Jesus Alvarado -
Windows 10 Pro 64 bit - i7 CPU 4770k
Asus A97-AR mobo - 32gb DDR3 ram
Samsung 850 evo SSD 500gb - Radeon 470rx
Corsair 750w PSU
Lynx Aurora 8
Clarett Pre 8 X Thunderbolt - Protools Ultimate
Avalon 2022 - Octane 8 - Scarlett Dynamic 8pre
Uad 2 quad - Waves Gold
McDsp Emerald - Duy Everpack
Tc Powercore Firewire
Old 07-16-2017, 10:12 PM
Sorry for the late response.
Okay so I got balanced cables and it eliminated the humming sound completely. So that worked.
As for the static knob turning sound. Cleaning the dirty pot sounds interesting. I will make sure to work on that this week and let you know if it fixes the problem.
Now to work on some drum kits.
Old 07-17-2017, 03:29 AM
Glad the cable deal worked. Hopefully the pot cleaning will work as well - just remember to unplug the unit from the AC mains.
Putting together drum kits from separate drum samples can be a challenge. One of the hardest things is getting the levels to sit well with each other kit piece. Especially cymbals.
Jack
QAPLA!
Old 07-19-2017, 07:01 PM
I hear the static sound again when I play each key on the keyboard. It was working a few days ago. I don't think it can be from the cables because the humming sound is still gone.
I restarted the computer and turned off and on the console and the keyboard. Still the same.
Old 07-20-2017, 08:59 PM
Here how it sounds.
https://we.tl/9L9JxKARxX
Old 07-22-2017, 12:12 AM
So I cleaned the pot and no more noise when I turn the monitor knob.
However I don't know why I get a static sound when I play on the keyboard. This comes and goes.
Static and distortion of sound while keyboard is plugged in to Digi 002 chumzels General Discussion 10 06-13-2014 03:46 PM
PT Crackling Static Noise/Sound - Sample Rate Issue gavriil1 Pro Tools 10 5 11-27-2012 06:39 PM
Static Sound When Keyboard Plugged In??? Ransom Pro Tools Software (Mac) 2 12-27-2010 08:26 PM
002 96k recording issue..static Chrisfx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-25-2010 01:00 PM
constant NOISE sound and Static/Poping sound jaynyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2007 10:10 PM
