Old 10-22-2014, 11:34 AM
inSync inSync is offline
Default Hardware buffer settings
as I understand it the H/W buffer for playback/mix is automatically determined by the sample rate in the PT session and it is not user configurable. Should I just set the H/W buffer size for input/record in the Playback Engine dialog to 32 samples? What are the multiple choices for?
Probably a stupid question, but I'm asking anyway.
Old 03-05-2015, 05:17 PM
Default Re: Harware buffer settings
Thanks!
Old 03-05-2015, 08:21 PM
PMF Media PMF Media is offline
The multiple choice are there to let you determine how much "think time" you give the computer, in other words, how much time you allow the system to process the audio/plugs/automation etc. The larger the session (the more tracks, plug ins etc) the longer the HW buffer setting - depending on the power of your computer, the lower settings are there to allow for low latency playback while recording live instruments so that you can monitor playback as well as record at the same time. Latency and delay compensation are far from perfect in PT... but that's another story
Hope this helps.
Old 08-12-2017, 01:19 PM
Default Re: Hardware buffer settings
Hey,
did not see this until now. Thanks for answering. It made totally sense.
PLEASE, Someone help me understand Hardware Buffer Settings.... led5150 macOS 6 01-29-2014 06:06 AM
Hardware buffer settings. L-Dogg Eleven Rack 5 02-17-2013 12:25 PM
PTMP 8 << lower hardware buffer settings.. hooray! edgarbc1 Pro Tools M-Powered (Mac) 20 06-03-2009 10:54 AM
Hardware buffer size in relation to DAE buffer sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2006 10:30 AM
Hardware buffer size settings? Eddie D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-03-2005 01:48 PM
