Old 03-27-2009, 11:51 AM
audionerdio audionerdio is offline
Default Analog outputs on 002R about 12db quieter than ADAT
Hey everyone,
I'm a long time lurker here on the DUC so first off, thanks for all the help over the years. I appreciate the wisdom.
I'm having a problem with my 002R. The analog outputs are about 12-15db quieter than the ADAT Lightpipe outputs that I have running through an Apogee Rosetta 800. I have both units hard wired to my patch bay but the problem exists even when I bypass the patchbay completely. I am just wondering if anyone has experienced a similar problem. There is no distortion on any of the outputs, just less level. I'm using a MacBook Pro, PTs 7.4 cs8 with OS 10.4.9. It wouldn't be much of a problem for me if I weren't trying to use my Dangerous 2Bus.
I'm assuming I have a problem with my hardware but I'm not sure. Normally when something goes wrong electronically inside, the volume would cut completely, not just drop in volume. Correct? Could it be a software or firmware issue? Any suggestion would help.
Thanks
-Slick
Question on digi 002r analog outputs kierkegaard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-21-2013 02:04 AM
Digi 002R Analog Outputs boost low frec and more....HELP! polen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-01-2008 01:27 PM
more analog outputs BaileyBass Pro Tools TDM Systems (Mac) 2 06-13-2007 05:45 PM
Simultaneous ADAT and Analog outputs mixman4000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-12-2006 06:08 AM
192IO:why do analog signals come back 6db quieter? Trailerman Pro Tools TDM Systems (Mac) 5 11-22-2005 12:07 PM
