I woke up and it wasn\'t a bad dream after all!!
I have a G5/2.5/4gigsRam/002r/PT7/focusrite octepre/
please somebody help me..this has to be a PT problem because I've had 3 or 4 others email me with the same issue wondering if I'd fixed it..when I posted 2 weeks ago... I've been out of town so i was starting to hope that somehow it was just a bad dream... i can't tell you how excited I was to get down into the studio tonight and do some good work only to be sorely disappointed... the history: So i bought this g5 with 2 gigs ram installed.. very groovy.. but typically I use a lot of tracks and some softsynth stuff along with a modicum of plus ins..so even though I'm doing what I've always done. ie record at 128 mix and edit at 1024 I still get the"I want to smash this stupid computer why did I ever sell my tape machine" otherwsie known as the dreaded "operating system held off too long.. bla bla try increasing bla bla bla (6086).." message so i figure, HEY! I know.. get PT 7 and 2 more gigs of overpriced fancy Mac Ram.. then I'll be cruising.. right? Wrong! it's worse than ever.. I can be running 4 tracks , no plug ins, nothing, and THE message comes up..if I increase the buffer to 256 i get latency which i can live with it except that it doesn't hold up more than 50% of the time.. YES i checked the RAM.. the G4 "sees" it. YES I've removed it and re-installed it. All my other apps are lightening fast..photshop,final cut, soundtrack.. so what's up guys!! sdjavascript:void(0) |
Re: I woke up and it wasn\'t a bad dream after all!!
well.... it happens...
PT 7 seems like is not too stable...if fact is not stable... people should know that a G5 and 2+ of RAM will NOT have you crusin with Pro Tools.. I have a G5 and run PT7 and I get those same errors for no freaking reason... I just keep working and sometimes it happens, but luckly most of the time it doesn't... |
What Mac OS version are you using?
I actually have 4 gigs of RAM and the problem got worse when I added the new RAM..
I am running 10.4.5.. come back PT6.9.. all is forgiven!! |
10.4.5 if not yet supported by Digi...10.4.3 is the last one that Digi supported...
Peoples! If you are not getting some sort of good performance of Pro Tools with 1 or 2 Gb RAM...
Do NOT go and buy more... |
So maybe this is the issue...the Mac OS!! Oh [bleep].. can I go back and put 10 .4 .3 in?
and yeah I know maybe I shouldn't have bought the extra RAm but it always seemed to me that the more ram you have for these things the better they run.. at least the macs I've owned for the last 15 years did.. has something changed? Less Ram is good? I'm confused man.. |
pt only uses 2 gigs max of ram 2.5 will be sufficient for total onboard ram to run pt and the OS. you must check all 3rd party plugs for updates for 7.0 and maybe it will get a little better
Mac Studio M1 Max, 32gb, 2023.12 ultimate, HDNTB, Aurora 16 LTHD, 13.6.3 |
Have a look at the OS X Activity Monitor (Applications Utilities) on the System Memory tab to figure out what your system is actually using. If there's already lots of free (unused) RAM left, adding another Gig won't improve anything. Unfortunately there's no "Undo" button for OS upgrades.... Going back to 10.4.3 means reinstalling from the supplied Tiger CD and then applying the correct upgrade package (downloaded from the Apple site) related to the CD version.
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder |
I upgraded to 4.5GIG and noticed a dramatic improvement in virtual instrument performance (but I use a lot of VI's!). Depends if you use a lot of VI's. It's my guess that neither 10.4.4 OR 10.4.5 will be supported by Digi.... 10.4.4 is by all accounts terribly unstable, and 10.4.5 seems to create lots of buffer underrun errors. If you stick with 10.4.3, and the latest PTLE update it's as stable as PT has EVER been (and that's really solid!) PT7 is more sensitive to plugins being up to date though. But if your plugs are up to date, then it rocks.
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe |
Woke from a dream... | Shifted Music | Pro Tools TDM Systems (Mac) | 2 | 01-26-2010 10:54 AM |
Woke up today and PT won't launch | David Francis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-21-2007 04:49 PM |
Woke up this mornin' got myself a DIGI002 problem! | theflash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-16-2005 09:27 AM |
I Just Woke Up And...! | T.Hyland | General Discussion | 3 | 06-05-2001 10:24 AM |
Woke up this mornin' | Lee Blaske | Pro Tools TDM Systems (Mac) | 3 | 02-28-2000 02:03 PM |
