hangs/crashes
I have a dual 867, 768 mb of ram, & three internal ata drives (60x80x80), using an Mbox & PTle on OS 9.2. I'm cutting dialogue for a t.v. show, running video, audio & applications each on separate drives.
I haven't been able to work due to crashes that occur minutes into the edit. Sometimes when I attempt to name a section or just idling. It's been fine until now. Does anyone have a solution? |
Re: hangs/crashes
Oh god, I have had the same exact problem and it's very frustrating. I did everything to no avail. Initialized my HD and reinstalled everything and it still happened. Then I figured out a couple of things and it worked.
First I updated the drivers on my hard drive using apple drive utility. It doesn't initialize the HD just updates the drivers. Then I took out of my extensions folder (in the system folder) the Quicktime VR extension and put it in my extensions disabled folder. Then I went into my Norton Utilities and defragmented every hard drive that I have. I don't know why but it worked fine after that. It's worth a try. |
Re: hangs/crashes
Thanks Kim. I ended up getting it to work by tossing my preferances, digidatabase forders ( automatically created on each drive ) & increasing the pro tools application's memory requirements to over 100mb. So far so good...
Re: hangs/crashes
Hi Again- That advice I gave you worked for a month after horrendous crashes all the time and after doing nothing different it started again. I switched hard drives and it helped a bit but it crashes every now and then. I slimmed down my Extensions and hold my breath everytime I record. So far it mostly works. I wish the company would clear this up with an update.
Re: hangs/crashes
PLEASE SEE
GENERAL DISCUSION>M-BOX ISSUES & >PT 6 & OSX |
Long hangs/crashes 11.02 HDX2 | fsavell | Pro Tools HDX & HD Native Systems (Mac) | 1 | 12-18-2013 04:27 PM |
PT7.3.1 BUG: renaming region hangs/crashes PT | christianwicked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-05-2012 10:41 PM |
8.0.1 -> 8.0.3 = Hangs and Crashes | paranerd | Pro Tools TDM Systems (Mac) | 2 | 02-05-2010 09:16 AM |
Help PTMP8 hangs/crashes on exit | DTheone | Pro Tools M-Powered (Win) | 13 | 03-11-2009 10:18 AM |
MBox2 Still Causes Hangs/Crashes | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-27-2008 10:40 AM |
