8.0.1 -> 8.0.3 = Hangs and Crashes
After updating to 8.0.3, I have been getting a Russian Roulette of issues. Sometimes when launching PT right after booting, it will just hang and needs a force quit. I'm mixing a session, save and close it, reopen it and it will crash while building region lists. I try the same session right after and it will open. Sometimes on the loading screen it will even hang the whole computer and I'll have to do a hard reboot.
When PT is running and I'm able to work it works fine. It's only when I'm launching or opening a session where I get issues. I thought it might have been my Canopus 110 because of a previous thread I read here, so I unplugged it before launching PT and it still hung. Relaunched and it opened. I updated to 8.0.3cs1 just to see if it changed anything and it didn't. Here's my setup: MacPro 2x2.8Ghz Quad-Core Intel Xeon 10.5.8 4GB DDR2 800Mhz RAM PT HD3 1x96 I/O 1x888 I/O Sync HD Command 8 Cedar DNS 3000 Canopus ADVC 110 Western Digital External 1TB HD |
Re: 8.0.1 -> 8.0.3 = Hangs and Crashes
It is the Canopus box that is the root of the crashes, it is a known bug. Search for this thread, "ProTools 8.0.3 Big Bug". Workarounds are discussed there. In a nutshell workaround #1, disable Canopus box before loading session. Workaround #2 rename Picture Folder where pix files reside before loading session, relink to picture files after session loads.
Found the link, http://duc.digidesign.com/showthread.php?t=263329 Digi has responded and is aware of bug and is working on a fix |
Cool, thanks for the prompt response and aforementioned thread!
Long hangs/crashes 11.02 HDX2 | fsavell | Pro Tools HDX & HD Native Systems (Mac) | 1 | 12-18-2013 04:27 PM |
PT7.3.1 BUG: renaming region hangs/crashes PT | christianwicked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-05-2012 10:41 PM |
Help PTMP8 hangs/crashes on exit | DTheone | Pro Tools M-Powered (Win) | 13 | 03-11-2009 10:18 AM |
MBox2 Still Causes Hangs/Crashes | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-27-2008 10:40 AM |
hangs/crashes | soundhealer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-20-2003 12:48 AM |
