Help with BFD2 2.0.1 settings with PT 8.0.3pr and TD-6
Hi all...
First of all an explanation of my setup: Mac Pro 2.66ghz with 10GB RAM running OS X 10.6.1 003 Factory Complete Pro Tools LE 8.0.3pr BFD2 v2.0.1 Roland TD-6 connected through Edirol UM-2 Ok... I'm wondering if anyone has had success with BFD2 in 8.0.3pr? I have tried creating a new session, with just an instrument track with BFD2 inserted and one Audio Track. No other tracks or plugs inserted. With BFD2 engine and Pro Tools playback settings set to defaults and using internal clock I keep getting the following error... 'Lost communication with the audio interface. Please try increasing "H/W Buffer Size" or removing some plug-ins, and make sure you have a valid clock source. Press OK to reset device. (-6097)' I can load my keymap, a kit and start playing ok... but in what appears to be a totally random fashion I get the above error. I have tried increasing the buffer to 512... which affects latency, but I still have the same problem. Anyone have any suggestions. Oh... and on another note... how the heck do you get choke to work on a CY-8? I've clicked the choke with aftertouch box and it still doesn't work. Thanks to anyone who may be able to help.
MAC Pro 6 Core 3.33 24GB RAM/ OSX 10.8.5/ Pro Tools HD 10 and 11.2.0 Native with OMNI/ KORG M3-88/ KORG Radias R/ KP3 & Kaossilator Pro/ Roland JV-2080/ Rode NT1/ Takamine TAN-15C/ ESP VB-400/ PRS McCarty/ PRS SE/ Yamaha TRB5II/ Jackson Flying V/ various BOSS pedals/ MESA Rect-O-Verb 25/ DV Mark C212V/ Roland TD-6 Kit with extras/ Yamaha & KRK monitors/ Lexicon MPX 100/ Behringer Powerplay Pro-XL/ Alesis 3630/ Many softwares :) |
Re: Help with BFD2 2.0.1 settings with PT 8.0.3pr and TD-6
1) Get build 2.1.0.47
2) Pro Tools defaults to filtering all aftertouch events... change your MIDI settings in Pro Tools. Rail
Hi Rail,
Thanks for the response... have updated to 2.1.0.47 and the crashing seems to have gone so far. Also... I think the choke may have been working all along, but the cymbal choke fade settings at default were so long it didn't sound like it was working :). I also found the MIDI filter settings in Pro Tools which I hadn't stumbled across yet, so thanks. I have only one last problem now... I've got the Hi Hat pedal working ok... but have a strange issue. I have the tip and shank both mapped correctly to variable. The tip works fine and sounds great from open to closed, but the shank doesn't sound at all when the pedal is closed. I have to open the pedal a fraction for the shank to produce a sound. The numbers on the articulation zones are set the same on both the keys for tip and shank. Any ideas?
Everything sorted now... very very happy.
Now for some expansions perhaps...
I have them all, I can highly recommend the Jazz and Funk pack, some lovely, lovely close mic snares and toms.
My whole library is 242 GB and thats BFD and BFD2 with all the expansion packs :-D |
do you have a midnam for the Roland TD-6
Upgraded to Win7 and PT10 - Cant get BFD2 sesion settings back | jayjaystevens | Windows | 2 | 10-06-2012 10:27 AM |
Do I need to buy BFD2 or BFD2 upgrade if I have BFD ECO? | joedexter23 | The Drum Room | 26 | 07-23-2012 11:38 AM |
BFD2 or BFD2 upgrade from BFD ECO?? | joedexter23 | Virtual Instruments | 2 | 03-11-2012 12:42 PM |
BFD2 - CPU/RAM usage too high, despite using 16b and load on demand settings | promusix | Pro Tools M-Powered (Win) | 0 | 01-15-2011 04:24 AM |
Bfd2 | tommykoot | Pro Tools M-Powered (Win) | 1 | 11-03-2010 05:58 PM |
