What are you guys using for drive imaging/backup?
I'm getting ready to make the full switch to Mac from Windows for my HD rig, and wanted to see what you all use for drive imaging/cloning software with your Macs to keep backups of your system drive, etc.? Thanks.
Re: What are you guys using for drive imaging/backup?
Archiving Retrospect and AIT 3
Daily back-ups USB 2 Drives and Synchro Pro X |
Retrospect on firewire disks.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
I used carbon copy cloner and it worked fine. Only a couple of challenge response codes needed sorting out when a drive failed.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
Superduper
Having switched from Retrospect, I've been using Superduper for the last year. It's been great. Superduper costs $28, offers a sensible GUI, and makes a seamlessly bootable clone of your system drive. I backup to LaCie FW800 drives and feel quite safe with my backups.
http://www.shirt-pocket.com/SuperDuper/SuperDuperD Best, John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Re: Superduper
I wouldn´t feel safe with a backup on a LaCie-Drive.
Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Superduper
Thanks guys, I'll check some of those out...
Re: Superduper
I also switched to Superduper and love it (recently saved my A@@ when a drive failed), Much better than CCC. Also ditto on the Lacie, I would not back up or use one.
Mac Pro: 3,1, 8 core, 6GB RAM. OS 10.6.8, Protools 10.3.8 TDM HD2 Accel. |
Apple has a built in tool called iSync that is supposed to do the trick. I have not tried it. I went thru this a few years back and decided to use a program called Synk to move the files to other drives. Synk only copies what has changed and also moves old versions of files to an archive folder, so the risk of overwriting a good file is eliminated (case in point would be if a session file got corrupted and you had not changed the file name in awhile. . . copying your existing session over you old backup would overwrite the last good session file). From there I use a separate old Mac G4 to move to tape running Retrospec and an AIT drive. I must admit I rarely do that these days (only for off premise backups), maybe 2-3 times a project, because it is so slow and I feel fairly comfortable with the Synk backup copy on a second hard drive. Below are some links:
Synk Backup Software
...for system configuration info see my profile (Click on member name) |
Imaging an SATA Drive in DOS? | cwsand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-10-2009 02:30 AM |
External Drive (Enclosure and Drive Build) and Backup Help | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-16-2008 08:18 AM |
Drive Imaging Question | arb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-29-2006 04:52 PM |
Imaging hard drives for backup under OS 9 | Dimension Zero | Pro Tools TDM Systems (Mac) | 1 | 07-27-2004 09:48 AM |
drive imaging / ghosting | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 10-06-2003 10:41 AM |
