Old 05-11-2004, 03:35 PM
gregor rasek gregor rasek is offline
Default bouncing song with reason...
hi,
i´ve done a little songy... and playback runs smooth- i can hear all tracks within the aux-track on which reason is assigned to. also while the bounce-process i can hear the reason-track - but the bounced track doesn´t include my reason track... especially i can hear in the bounced file the drum-intro until bass-guitar (which also is made with reason/midi) beginns to play. i set a midi-channel to NN 19 - the NN19 outs are assigned to the nn19-channel at the reason-mixer - from there i send the bass signal via an aux-send to reasons hardware interface output 3. in PT i´ve created therefore a seperate mono-aux-channel which receives the NN19...
- so reasons redrum comes out through reason-channel 1+2 - and the bassguit/NN19 comes out through
reason channel 3 - ... i don´t know if this causes the problem....
any ideas...
O.R.S. - recording engineer - www.overdub.at
Old 05-11-2004, 04:16 PM
Roy Howell Roy Howell is offline
Default Re: bouncing song with reason...
When you bounce, make sure have 'Low Latency Monitoring' off/unchecked (it's under 'Operations'). Otherwise, you'll be bouncing audio tracks only.
-Roy
rh music
Bouncing song for use on another program? like Logic? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-05-2007 03:10 AM
How do I trim or truncate a song before Bouncing autonickv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-16-2006 12:14 AM
Problem Bouncing Song... Strantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-21-2006 12:35 PM
Speeding up a song while bouncing to disk Moxon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-09-2005 03:19 PM
Help with bouncing my song to file to be burned trope75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-20-2002 10:00 AM
