Old 02-26-2007, 07:18 PM
Chief Technician's Avatar
Chief Technician Chief Technician is offline
Default Re: What are you guys using for drive imaging/back
Superduper will backup ACLs, CCC will not. If you don't know what ACLs are, don't worry, but if you do, make a note of that fact.
You may be able to use the rsync command in Terminal, though I don't know what metadata it won't preserve. Each backup strategy preserves certain types of metadata. You may want to try googling the net to see what does what.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 02-27-2007, 02:56 AM
25ghosts 25ghosts is offline
Default Re: What are you guys using for drive imaging/backup?
Retrospect
www.dantz.com
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 02-27-2007, 02:59 AM
Rail Jon Rogut Rail Jon Rogut is offline
Retrospect.. even though it doesn't work with the DVD burner in my Mac Pro.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-27-2007, 03:29 AM
Steve MacMillan Steve MacMillan is offline
Another vote for Retrospect.
STeve
macmandigital.com
Old 02-27-2007, 03:38 AM
Deja Vu.
frank.
PTHDn 2019.10 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 02-27-2007, 04:02 AM
remainanon remainanon is offline
Rail
Rail, have you done anything with the firmware on your DVD drive? I got mine to do all sorts of new tricks...
JW
Old 02-27-2007, 05:25 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Retrospect and AIT2
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2019.6, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2019.6, MBox3
Retina MacBook Pro OS 10.14.5, PT2019.6
Old 02-27-2007, 05:30 AM
mtung mtung is offline
Retrospect and AIT2 here as well.
mike
Old 02-27-2007, 07:07 AM
thin ice thin ice is offline
I thought it meant anterior cruciate ligament. I'd be interested to know what you meant though.
Mac Pro 2.66 Quad-Core Intel Xeon
6 GB 1066 MHz DDR3
HD3 Accel PT 9.0.6, OS 10.6.8
Old 02-27-2007, 07:14 AM
Tony Shepperd Tony Shepperd is offline
Retrospect and AIT2
Mixing in the box, requires thinking outside the box.
My New Instructional Mixing DVD 2 is Shipping
www.tonysound.com
http://twitter.com/tonysound
Imaging an SATA Drive in DOS? cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-10-2009 03:30 AM
External Drive (Enclosure and Drive Build) and Backup Help JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-16-2008 09:18 AM
Drive Imaging Question arb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-29-2006 05:52 PM
Imaging hard drives for backup under OS 9 Dimension Zero Pro Tools TDM Systems (Mac) 1 07-27-2004 10:48 AM
drive imaging / ghosting kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 10-06-2003 11:41 AM
