Is getting a used PCIx system a good idea?
Is getting a used PCIx system a good idea? Financially, you can get a used HD3 PCIx with a 192 and PC/MAC for a lot less than just the one PCIe Core card.
How much performance is sacrificed by going with the PCIx ? Any thoughts would be great. |
Re: Is getting a used PCIx system a good idea?
Mine is working great.
I just got a used Accel card for $700. I'm now HD 4 and lovin' it!
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
- PCI Accel (PCIx): the HD Core card is not an Accel card - PCIe Accel: the HD Core card is an Accel card Once you go to (or above) a HD 3 Accel the difference between PCI (PCIx) and PCIe is not really noticeable. Btw, Avid still sells PCI Accel (PCIx) cards at full price, when you buy a brand new HD Accel system you can still choose between PCI or PCI-e cards, the price is exactly the same... So the very low prices of used PCI (PCIx) systems can be very interesting...
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
i got an pcix system and i researched the process cards because i didnt know about acell vs regular processing cards.
the difference is not that great. its about 15%-20% faster overal. but the plugins coded in acell, which can only be used with acel cards, then the acell card will be much faster. and non accell cards are very inexpensive. as for pci-e and pcix acell im not sure. i think it is the same card except the throughput will be bigger as its inherited in the pci-e specs. but as someone pointed out above, if u go hd3 pcix then i doubt youll run into issues. |
So, if you have a PCI system that is HD3 or higher, the difference in performance is minimal compared to PCIe ?
For all relevant info, please read this document: http://akmedia.digidesign.com/suppor...ower_26690.pdf
--Jeremy |
Is a PTHD2 PCIX w/ G5+control24 still good for commercial studios? | gsilbers | Pro Tools TDM Systems (Mac) | 1 | 10-27-2011 08:33 PM |
Idea of a system, not sure if good. | Soup | Digidesign Hardware & Software | 3 | 08-25-2008 06:41 PM |
Good Idea/ Bad Idea | Slade | General Discussion | 0 | 07-24-2003 07:30 PM |
onboard sound, good idea/bad idea?! | sampb7 | Digidesign Hardware & Software | 1 | 02-22-2003 02:44 AM |
Buying my TDM system now, a good idea ? | lionel payet | General Discussion | 21 | 01-17-2002 01:33 PM |
