#81
Can't Run PT 12.8 License Error
I just installed 12.8, and when I run it, I get an error that says "You are trying to run a newer version of Pro Tools than allowed by your license"
I have never had this problem, and 12 is on my iLok, 12.8 is in my account. I have successfully run all versions of 12 so far. I ran Application manager and get the same result. My account is active until December of 2017. Any ideas welcomed- -dj
iMAC 3.2GHz 6-core i7 250GB SSD (internal) 1TB SSD (external) 16GB RAM OSX 10.14.5 PT 2019.10 (last one) Waves Gold/RenMaxx v11 iZotope Ozone 8 Focusrite Clarett 8Pre Nord Stage 3 Nord Lead A1 DSI Mopho X4 |
#82
Re: Can't Run PT 12.8 License Error
#83
Make sure you sync your ilok aswell after updating the ILM. Use the sync repair fucntion and see if that does it.
#84
Maybe you need to refresh your liscences in the iLok manager
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com |
#85
Thanks for the input-
I ran ILM from my Mac and everything was there. I logged in, and it showed all my licenses. I then ran Pro Tools and it loaded properly. Never sure of the sequence of events to get each new version running. Thanks again- -dj
#86
Re: "You are trying to run a newer version of Pro Tools than allowed" error
Can't create a case. Eveytime errors when I send the form. This is getting annoying.
Edit: Finally managed to create a case and within 30 minutes I got a working license. Pro Tools 12.8 is now working! Last edited by FritsFlits; 07-03-2017 at 09:42 PM. |
#87
linkedin
#88
HI,
I have all the symptoms mentioned here. Followed the ilok uninstall/install procedure shown at the beginning of the thread, the 'release limit' is also 01/04/2017 though my license is valid till 31st of march 2018. I started a support case some minutes ago. 27
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+ |
#89
Just started a support case. Uninstall/reinstall didn't work.
With all due respect to hard-working Jeffro, everyone who purchased PT11 and then switched to subscription has a perpetual license that expired in January or at the end of March. This bug will affect thousands. But even so, fix mine first! (minutes after I posted this, Avid called me and fixed the issue. Pretty impressive speed! all good now. 12.8 here I come...)
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn Last edited by reichman; 07-04-2017 at 06:21 PM. Reason: update |
#90
Hello,
I'm also receiving this error after trying to upgrade to 12.8. My rate limit in iLok manager states versions released on or before 3/31/17. yet my annual upgrade plan does not expire until 3/31/18. I tried opening a support case via phone but was informed that I had to buy a single support case in order to talk to a human being. Instead I tried filing a case via the web form and received this case number 03242229. @jeffro is this something you can help me with? Oh and yes I'm using the latest version of iLok license manager, 3.1.7.899 Best,
OS 10.12.5 - 32GB - iMac Late 2013 - 3.5 i7 - Pro Tools 12.8 - UAD Apollo Twin |
Pro Tools 10 won't open session file (Created on a newer version) | sjafarzadeh | Pro Tools 10 | 8 | 06-14-2023 11:24 AM |
This session file was created by a newer version of Pro Tools [7.4.2f109] | olivergodfrey | Pro Tools M-Powered (Mac) | 3 | 02-12-2013 04:53 AM |
unable to install bfd lite for pro tools 8 beacause newer version already exists? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-25-2009 12:00 PM |
