Old 08-27-2012, 02:59 AM
Oblivion777's Avatar
Oblivion777 Oblivion777 is offline
Default [SOLVED] PT10HD License but HD features are missing
Hi!
I've just finished with a clean install of PT10.2.0 on my new MacBook Pro. I've purchased the PT10HD bundle and have put that bundle on my "new" iLok. If I log on to my iLok account I have these licenses deposited on it:
PT10HD + PT10 + PT9HD + PT9
I've obviously installed PT10.2.0. Now I thought that PT10HD license enables all the features of PT10 with CPTK license which would mean that I get features such as disk cache, but I don't. I have access to VCA's for example, but no disk cache. When PT starts/loads the screen does display PT10HD.
Is the disk cache feature not enabled if you run PT10HD natively without any Avid hardware?
Main DAW: MacPRO 7.1, 16-Core Xeon 3.2GHz, 196 GB RAM, OSX 10.15.2, HDX3, PT 2019.12 Ultimate, 2x UAD-2 PCIe Octo's, Raven MTZ, 1x HD Omni, 2x HD I/O's, 1x MTRX and some more cool stuff...
Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x)
Old 08-27-2012, 05:29 AM
Question Re: PT10HD vs. PT10 License
Originally Posted by Oblivion777 View Post
Hi!
That is correct.
Really?
What makes you say that you do not have access to the disk cache?
As it should if you have an HD license.
No. The disk cache is available without AVID hardware.
Old 08-27-2012, 06:39 AM
Default Re: PT10HD vs. PT10 License
If I go to "Setup\Playback Engine" I only have the Disk Playback and Plug-in Streaming Buffer options; there's no option to select the amount of RAM that is dedicated to disk cache. Furthermore if I look at the System Usage monitor I only see CPU (Native), CPU (Clip) and Disk percentages; again no disk cache.
I don't get it.
Thanks for the help!
Old 08-27-2012, 06:43 AM
Right; I am sorry. Stupid me...I've overlooked that the Disk Playback cache size was set to "Normal" as opposed to a real value.
My bad! ... Now I really do feel stupid for posting this in the first place...
what happens to my PT10hd license if i upgrade to PT11hd rustyjay macOS 2 01-22-2014 11:00 PM
Transferring PT10HD license with hardware Tim R. macOS 11 07-22-2013 12:32 PM
Transferring PT10HD license with hardware? Tim R. General Discussion 4 06-18-2013 01:52 AM
Wanted: Full PT10HD License Table Syrup Records Buy & Sell 0 06-29-2012 06:59 AM
PT10HD Bundle ilok license question Lizardpoint Pro Tools 10 2 01-15-2012 09:34 AM
