Old 05-08-2015, 04:38 AM
HansSchumann HansSchumann is offline
Default Temporarily Suspend Track from Group and/ or VCA Automation
Hello there,
anyone an idea on that one?
How to Temporarily Suspend Track/s from Group and/ or VCA Automation?
I tried to write volume automation to all members of a group - with or without VCA master - exept one (or some) track that should be temporarily suspended on an automation record path.
If i get it right PT 11.3.0 offers the opposite:
"Temporarily Isolating Control of an Item from Group Operation
You can temporarily isolate control of a group item from group operation by Right-clicking on the item.
You can also temporarily suspend group behavior for a track by Control-clicking (Mac) or Start-clicking (Windows) a group function."
But that seems to need to (control-) move/ touch the actual fader of the track to be suspended. Which makes it impossible to move the VCA master fader at the same time?
I would like to have a button/ shortcut that just sets the channel out of the group temporally, without having to go via group-dialog-window every time.
Is there a trick or is it not provided?
Thanks & regards
Hans
Suspend automation lindellsound Pro Tools 11 3 12-08-2015 04:47 PM
Suspend automation issue ianfleming1992 Pro Tools 11 5 02-08-2015 12:50 AM
Suspend Trim automation Bart HLH Pro Tools TDM Systems (Mac) 1 11-16-2012 04:15 PM
Use of Suspend Automation ramu745 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2009 08:18 AM
7.3.1 cs 5 & group suspend button ! ? priorytools ProControl, Control|24, Command|8 2 10-16-2007 01:59 AM
