  #51
Old 02-28-2020, 07:36 AM
mirovaz mirovaz is offline
Default Re: License Verification Error - need help
Originally Posted by filmsdunjour View Post
iLok Cloud is down for everyone, guess we have to wait for iLok offices to open?
Thanks for the answer.
Hope this gets fixed ASAP
MacBook Pro M1 16G RAM
OSX Big Sur 11.6
ProTools 2021.10
UA OCTO Thunderbolt, UAD Twin MK2 QUAD
  #52
Old 02-28-2020, 09:35 AM
mottsimon mottsimon is offline
Is there anywayto avoid this in the future.Can having hardware ilok mitigate and issue such as this. It seems crazy to me that users are at the mercy of the cloud. Why can't sessions be worked on offline?
  #53
Old 02-28-2020, 07:05 PM
TNM TNM is offline
Does the subscription allow you to choose dongle authorisation over the cloud? The reason many companies don't allow their products to be authorised to the machine locally is that it's been said, clearly by Michael of exponential audio (now izotope), that ilok "soft" auth is the weakest of the lot and has been previously breached (even though it's been updated again since then).
So these companies give you the option, cloud, which is never breached, or the dongle, which ditto, for many years now. But not the local machine (i.e the computer).
Are you totally against the idea of having a tiny ilok3 dongle plugged in? All it will do is refresh once a month for about 5 seconds if you choose that method, or once a year if you paid for a year in advance. That's it. You can be offline at all times otherwise.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
  #54
Old 02-29-2020, 03:13 AM
clusterer clusterer is offline
Default Re: License Verification Error with iLok Cloud
Are there any reactions by Avid or iLok - nothing, no apologies, nothin about the cause? This was a real nightmare yesterday... a true kakka day!
Seems that they both don’t care about their costumers.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
  #55
Old 02-29-2020, 07:30 AM
TNM TNM is offline
has anyone written to them to even inform them what happened in case they are unaware, and to get an official response?
  #56
Old 02-29-2020, 09:24 AM
Avid's Avatar
Avid Avid is offline
Administrator
Post Re: License Verification Error with iLok Cloud
Apologies for the iLok Cloud outage yesterday.
We are working with iLok to understand the root cause and will update you when we have more info.
Administrator
  #57
Old 03-01-2020, 12:32 AM
frenchman frenchman is offline
Ok its time for apologies etc but my main concern is making sure not that it may not happen again EVER, because **** (always) happens.
I want to make a constructive suggestion :
Since many people working with cloud licences are 100% dependent on their pro tools to work (for me no protools means no studio means sending clients home !) there should be a mechanism by which an emergency code (to be used only once) can be put in the ilok manager to make everything run for 24 hours in full autonomy.
I leave it to Pace to devise the way to manage this, it should not be that complicated, once devised the way to prevent pirates from using the feature for their own purposes
Mark Haliday
CUSTOM STUDIO
Pro Tools HDX Ultimate
Mark Haliday
France, Rochefort 17300
Mixing & Mastering, Writer, Teacher
Pro Tools Ultimate & Carbon
M2 Max Studio
  #58
Old 03-01-2020, 01:44 AM
Sardi Sardi is online now
Default License Verification Error with iLok Cloud
I totally get your frustration and in an ideal world, there wouldn’t be any downtime.
But... is there a reason you won’t use the dongle instead? Your studio needs to be running all the time. Why not use the physical dongle? It’s about as close to zero downtime as you’ll get. Yes, I’m aware the dongle can fail. =P
I like your suggestion, but I guess if the server is down, the likelihood of depositing a temp license into everyone’s account is pretty slim.
  #59
Old 03-01-2020, 01:49 AM
The point was there already is a procedure for replacement license for a broken dongle, but there is nothing for disconnected cloud. If your license is in the cloud and the cloud is inaccessible, you are out of luck.
  #60
Old 03-01-2020, 03:07 AM
I’m aware of that. Not sure why you quoted me.
iLok Cloud Error jchan Pro Tools 2019 0 12-16-2019 12:52 AM
New iLok License Manager Released - Now Supports iLok Cloud Managed Mode unkJE Licensing & Accounts 0 10-10-2019 04:07 PM
iLok Cloud Error jchan Pro Tools 2018 6 05-07-2019 02:53 AM
License Error - Software Component Unavailable installing iLok License Manager martinaston Pro Tools 12 9 12-29-2016 08:16 PM
