Old 09-21-2019, 01:16 AM
spoons's Avatar
spoons spoons is offline
Default Suddenly PT won't load Plug-Ins because not valid 64-bit
OS 10.12.6 , PT 2019.6.0
Suddenly on booting up a session I had a AAE 7058 unauthorised plugin error. So I trashed prefs.
Now I have a few plug-ins that won't load because "they aren't valid 64bit" ? They have worked fine up to this point?
The only thing that's changed is I upgraded my iPhone to iSO13. When i plugged it into my mac I had a message come up saying that to connect my iPhone I bit of software had to download, which it did. Surely not connected ?
Any ideas ? I've trashed prefs (made it worse) and ran first Aid on the boot drive.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 09-21-2019, 04:41 AM
Default Re: Suddenly PT won't load Plug-Ins because not valid 64-bit
What exact plugins won't load? Avid or third party? For about a month or so I ran PT 2019.6 on OSX 10.12.6 and had no such issues. However when I went to OSX 10.13.6 I got a couple of plugins and h/w drivers that put up an error message saying they weren't optimized for 64 bit. I know current PT versions still have some 32 bit code.
It's possible whatever code that got downloaded during the iPhone upgrade did something untoward to your Mac. Do you have a good backup for your Mac? It's for times like these having a bootable clone of a working system will save your bacon. I use Carbon Copy Cloner to do the deed to an external drive that gets disconnected when the cloning is done which I do weekly.
Please tell me you don't have automatic updates turned on on the Mac.
Old 09-21-2019, 06:54 AM
mirovaz mirovaz is offline
This is exactly what happened to me yesterday and I wasnt able to fix it yet!!!
MCDsp EC3000 delays, Acoustic Audio ElRey Compressor and many others...
Could you fix it?
THanks
MacBook Pro M1 16G RAM
OSX Big Sur 11.6
ProTools 2021.10
UA OCTO Thunderbolt, UAD Twin MK2 QUAD
Old 09-21-2019, 02:08 PM
the19thbear the19thbear is offline
The exact same thing happened to me. The day before yesterday everything was fine.
Then today, all my AA plugins dont work along with mcdsp and phoenixverb.
I also updated my ios software.
What the heck?
Unusable.
Old 09-22-2019, 04:57 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Same issue happened to me. However, I rebooted my universe and the problem went away. It was a few Plugin Alliance plugins. For what it’s worth, I was switching from sessions with 48k to 44k as well. It seems to have resolved itself.
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 09-22-2019, 06:37 AM
Universe?:) no matter how many times I reboot, the problem is still there.
Old 09-22-2019, 08:18 AM
I just used TimeMachine and rolled back 2 days before the problem started.
Now everything is working like a charm. I just DID NOT connected my iPhone with the new iOS this time.
Tried lots of things (see my post about that). Nothing solved it!
The TimeMachine was the only thing that make things running again and I cant waste more days waiting for a software fix.
OSX Big Sur 11.6
ProTools 2021.10
Old 09-22-2019, 09:06 AM
Bummer. Don’t have time machine.
Hoping they will get a fix soon.
Old 09-22-2019, 10:16 AM
spoons's Avatar
I’ve started a support case and will report back.
Can someone chime in from Avid please ? What is this piece of software that runs when you upgrade your iPhone to iso13?
I have a backup so might try that.
My plugs that don’t work now are Nugen Upmix and Sonarworks.
Richard Spooner
www.spoonsound.com
Old 09-22-2019, 10:43 AM
Thanks a lot. Please keep us posted:)
"Not valid 64 bit AAX plug-ins" - almost all 3rd party plugins suddenly corrupt noiseboyuk Pro Tools 2018 13 10-13-2020 01:14 PM
falcon failed to load because it is not a valid 64 bit plugin fourthtunz Pro Tools 2019 1 07-09-2019 07:36 AM
Some UAD plugs "failed to load...not valid 64 bit AAX..." sfsonarboy AAX Plug-ins 3 02-04-2016 05:55 PM
Pro Tools Suddenly takes up to 4 minutes to load ashm macOS 5 12-31-2010 04:17 PM
PT 7.4 Suddenly Does Not Load Toonvox Pro Tools TDM Systems (Win) 7 07-15-2009 01:11 AM
