Transport stops screen freezes when I select plugs WHAT CAN I DO?
I never had this before,. Im working in OS 9.2 and when I try to select a operation or plugin my screen freezes during playback and then I get the tapping fingers of death and Im stuck. I did a search but I couldnt find anything. any info would be greatly appreciated!
Re: Transport stops screen freezes when I select plugs WHAT CAN I DO?
bump
Trash your PT preferences.
dk
www.dpksound.com |
I tried that but it didnt do the the trick, I trached DAE pref and PT LE pref is there anything I misses. I recently did a firmware upgrade on my G4 400, but Im not sure if that is when my problem developed.
more info on my situation
when my cd burner is on when I launch pro tools I get a message "pro tools hardware is not installed or in use by another program" toast dosent see my firewire burner in os9 everything in osX works great. I have trashed dae and pt pref zapped P ram reinstalled toast optimized my drive If anybodys got any advice, Im goin nuts Thanks |
Do you have the very latest Firewire drivers from Apple?
What version of Pro Tools? Disc cache in memory control panel set to 512 ? Also, with OS 9.x, there are three Prefs that should be trashed. -DAE prefs (whole folder) -Digi setup -ProTools LE prefs
www.dpksound.com |
I went in and trashed the digi set up
I have the latest firewire drivers for OS 9.2.2 version 2.8.5 I am using PT LE 5.2.1 32 track beta Thanks for responding, no changes yet but thanks again. |
protools problem....probably need to defrag. your hard drive.
I had the same problem with my firewire cd burner. It's because you installed OSX, which installed an OS9 disc burner utility. you have to disable 4 extensions in OS9 to get it to use toast as the system default. in extensions manager disable these exensions: "authoring support" "disc burner" "Firewire authoring support" "USB authoring support" Hope this helps Jeff |
It does sound like you have a hard-drive problem.
Your drive is probably fragmented >>> defrag now. Or your drive is slow >>> you have an older G4 system >>>> thus buy the latest PCI card with fast IDE-ATA-133 ports >>> and buy new fast drive to attach to IDE card.
www.CaveCyberNation.com |
I disabled those extensions, now my burner is working! Thank you very much. I still get the weird behavior in pro tools. How do I de frag ? I have pro tools on my mac drive. I never had any problems untill I upraded my firmware so I could use the 1.2 gigadesign processor.
I know the problem isnt the processor because I took it out and put the old one back in. and still the same weirdness. |
buzz when transport stops | Ty Ford | macOS | 2 | 04-10-2012 07:55 AM |
MC Transport - Jog Track Select | PlugSlut | Artist Series | 7 | 03-29-2012 05:56 AM |
How to select Transport=PT or MMC? | Rockman413 | Pro Tools TDM Systems (Mac) | 11 | 05-03-2011 11:02 AM |
DIGI 003 Transport vs. computer screen transport | ostrange | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-10-2008 12:38 AM |
HELP! Screen Freezes (just screen) While Running 6.1.1 on XP Home | Brentsky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-27-2004 08:54 AM |
