Worth using 2020.5 over 2019.5? Opinion.
I have not had time to switch over. Is it more stable? On 2 systems. A 5.1 on high Sierra and a 7.1 on Catalina that I have not setup yet. I do have 2020.5 on a MacBook pro 16. The only issue is folder tracks going back and forth to my studio. Studio is hdx with avid interfaces and macbook pro is in the box so not a real comparison. I am reluctant to change my studio system.
If it is not more stable I will stay on 2019.5. Thanks. Sent from my SM-G986U using Tapatalk |
Re: Worth using 2020.5 over 2019.5? Opinion.
Stable for me on Mavericks
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
I'm sure you are not running either 2019.5 or 2020.5 on Mavericks
OP is using High Sierra and Catalina.
IMO, 2020.5 isn't as stable as it needs to be. I'm still running 2020.3. |
+1 here. I've rolled back to 2020.3
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Just curious - what kind of stability issues have you experienced?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
If that's not the opinion of today's general public then I'd love to know. I'm still getting video engine crashes in .3 too often. And quirks with delay compensation. And CPU spikes. And poor distribution between my 24 virtual cores. And sluggish GUIs from some plugins (yes, it's possibly the plugin developer's issue to solve). And other things. .5 might be better with these things, but the impression I was left with after doing some research is that general bugs/quirks are even more bothersome. |
Update... 2020.5 had been reporting abnormally high CPU usage on a small 18 track session running at 1024, SWODing and crashing continually. It didn't stop when I rolled back to 2020.3, which had been very stable for me before. I noticed glitches in the GUI of Pro Q3 (of which I had about 8 instances) and updated it to the latest version, and that seems to have solved the problem.
Back to 2020.5. The heavily loaded session appears to be running smoothly now at 128 with a reading of 20% CPU, which it couldn't do before at 1024. I can now continue work, though I'm still watching. Hope this helps someone.
Quirks in PT 2019. Are they in 2020 too? | dansoundmix | Post - Surround - Video | 4 | 08-03-2020 11:00 AM |
I/O issues PT 2020.5 macbook Pro 2019 | Rmarcopolo | Getting Started | 1 | 07-12-2020 08:41 PM |
2020 versus 2019. | Cryos | Pro Tools 2020 | 1 | 06-17-2020 05:47 PM |
can I rename 2019.10 and install 2020 to have both? | arche3 | Pro Tools 2020 | 7 | 04-01-2020 09:21 AM |
Worth the upgrade? Your opinion? | Elton Hyland | General Discussion | 4 | 01-20-2017 03:52 AM |
