Help! High Frequency Tone (3k or so) randomly coming into channels during mixing
I was running Pro Tools 9 (9.3.whatever the latest version was before they switched to 10) on my iMac running OSX 10.6.8 and started getting a random
high frequency tone showing up in one channel after a while of mixing. This would happen on every session and it wouldn't go away until I would close out of the session and open it back up, or I would have to change the I/O for that channel and it would go away but then I would also be missing certain tracks during playback after that so would have to reopen anyway. I decided to go ahead and upgrade to 10 due to this and The Problem STILL REMAINS. Has anyone else had this same issue and know how to resolve this? I am in the middle of mixing an album and recording some acoustic and drum tracks for a buddy of mine and this is hindering my ability to work. Please help! Thanks in advance to anyone who has any insight. -David |
Re: Help! High Frequency Tone (3k or so) randomly coming into channels during mixing
Its not a tone generated by a demo plugin?
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
nope, it appears in different channels each time, I can't imagine what plugin would do that. any ideas?
maybe something is up with your interface and its sending the tone into pro tools.
Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
When it appears, bypass the inserted plugins one after another. That way you can see, which one causes it, or rule the plugins out.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Did you guys get this solved..It's very annoying. It seems that when I change the voice allocation the noise disappears, however shows up in other tracks as well. What is causing this and are there any updates for it? I'm running PT HD 10.3.5 on Mac OS 10.6.8.
Ideas? |
Your post is the only one I have seen announcing this problem. So I'd suggest it is in your system.
Muting your plugs one at a time may help in finding where it is coming from, like suggested. There is 10.3.6, made for co-installing 10 with PT11. How long has this been happening? Did it start after an update or loading new plugs?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
...and what is your system precisely?
This sounds like a plug in issue or preferences issue with that session.... If you dont find a plug in fix or by removing the plugins that doesnt fix it, than try importing the session data into a new session and it should reset the prefs for that session....
A LOT of little problems seem to be related to corrupt session data in my history of PT.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
It's not a plug in issue. Many of the tracks don't have plugins where the noise is present. Even upon importing session data- it still persists. I may have to run extensive tests to pin point it. Sometimes when I duplicate the track it goes away as I use the newly duplicated track. We have the same setup in our studio A and have never seen this issue there.
We still run our O2R into a 192 with PT HD 10.3.5 on OS 10.6.8 |
annoying frequency tone heard after midi to audio conversion | noaortiz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-26-2011 12:24 PM |
A very strange midi problem - getting a frequency/tone in my speakers | peht | MIDI | 2 | 07-30-2009 10:03 AM |
high frequency from monitors | fawske3n | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-15-2008 10:09 AM |
Help! I have a high frequency tone in my digirack | jeroententy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-26-2006 09:27 AM |
high frequency noise | vlad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-17-2002 12:09 AM |
