No input signal into 192
Hello people,
This is my first time using the conference so forgive me if I appear to be talking bollocks. I've got a 192, Control 24, and G5 running PT HD2 system. Whan I first installed my new 192 it was working fine (mic into C24 and imported audio), I've gone back to it 2 days later and now I'm not getting any input signal on my input meters. The only input that registers is imported audio. All cabling seems to be fine and is as it was when working, I think it's just a setup error but I've tried a few options but with no joy. I'd grately appreciate soe help and advice! Thanks all! |
Re: No input signal into 192
The control 24 doesn't remember the input selected!! between mic/line/instrument etc. so everytime you turn it on you have to select the input to mic? if you are using a microphone of course The 16 pre amps and line inputs that come with the C24 are actually totally seperate from all the c24 functions! and nothing is kept in memory, so everytime youe turn on you have to select what you want? and the hi-pass filter settings etc. Chris
No input signal | Nealeh | Windows | 4 | 11-19-2012 12:53 PM |
input signal | paldry | macOS | 3 | 08-26-2011 10:17 AM |
No input signal in PT | soundcannery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-17-2010 06:13 AM |
low input signal | artbrut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-06-2008 12:08 AM |
Help, in the 001 I have no input signal | Santos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-27-2002 11:46 AM |
