Old 08-23-2020, 09:08 AM
Rich Breen Rich Breen is online now
Default Re: Is the current Macbook Air acceptable as a B machine for Protools?
I occasionally use my very old (2013) Macbook Air for day-long remotes (up to 16 tracks, 96k) and it's been absolutely flawless; TB hub to hook up to two Metric Halo ULN8s via ethernet, external drives, display, and an Artist Mix - makes a great little remote machine. I have even occasionally opened medium sessions on it (50 tracks / 96k, modest plug in count) and it's been fine. It couldn't be my primary machine by a long shot, but for low track count sessions and smaller mixes it's been very handy to have around.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 08-25-2020, 11:28 AM
NewdestinyX NewdestinyX is offline
Thanks Mark & Janne! Helpful !
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
Old 08-25-2020, 11:33 AM
JFreak's Avatar
JFreak JFreak is offline
No problem. And for what its worth, I would not buy a laptop with 16GB memory today.
Janne
Old 08-25-2020, 11:37 AM
Mark Ziebarth Mark Ziebarth is offline
Janne is right. 16 GB is the minimum for Pro Tools today and the maximum for Macbook Air today. There’s no buffer for future developments...
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 08-25-2020, 11:42 AM
Yes.. if you’re doing all the A/D outside of the Air (Dante or MADI from an A/D box or even simply USB where the A/D is done in one of the Midas XR18 types of boxes. What’s killed Laptop recording on a lesser computer in the past is relying on the A/D of an ASIO unit hanging right off the computer.
The Midas XR18 has amazing sounding converters. And I can cut 18 tracks without a hiccup from my old MBP late 2011. I expect it will be just as doable thru a new Air.
Thanks for your input, Rich!
  #16
Why not? (Or was that a typo.. didn’t you mean you wouldn’t buy a laptop WITHOUT 16GB?) And no Airs come with 16 to my knowledge.
  #17
Old 08-25-2020, 11:44 AM
JFreak's Avatar
Originally Posted by NewdestinyX View Post
Why not? And no Airs come with 16 to my knowledge.
16GB was like 2013 and today I would expect to see 64GB on laptop and more on desktop. If you buy a laptop with 16GB today it is outdated the day you start using it.
Janne
  #18
Old 08-25-2020, 11:47 AM
JFreak's Avatar
But as your original question was, acceptable as B machine, then yes, you can get some work done when you spend time on hotel or wherever. Just do not expect that a machine with 16GB memory is future-proof
Janne
  #19
Old 08-25-2020, 11:56 AM
JFreak's Avatar
With that said; I am old enough to remember that a 80486 with 16MB memory was considered a powerhouse for a long time, until Pentiums came and soon 64MB was low range 128MB normal and 256MB high end. Memory-wise, the same thing is repeating itself, just replace MB with GB
(also old enough to remember 64kB was a lot one day...)
Janne
Time Machine Session Won't Open on New MacBook Pro Jepse macOS 5 10-06-2019 08:12 AM
2008 era MacPro 3,1 3Ghz Quad-Core vs current MacBook Pro 15" IVcrane macOS 4 01-09-2016 01:56 PM
building a new PC/upgrading current windows 7 machine thruhiker Windows 1 10-28-2012 06:07 PM
acceptable latency? therecordinghouse Tips & Tricks 4 05-10-2006 07:55 AM
acceptable volumn problem johnmo2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-15-2005 10:35 AM
