Old 09-14-2018, 09:19 AM
jpsexton's Avatar
jpsexton jpsexton is offline
Default S3 and MOTU or RME AVB and Windows
Has anyone successfully set up the S3 with an MOTU AVB interface on Windows?
Besides MOTU, RME has also introduced an AVB Windows interface and perhaps that would work as well...
There is a used S3 local to me that I am considering but if I can get the AVB working on my Windows system that would seal the deal.
Intel - Core i7-8700 3.2GHz 6-Core Processor
Asus - Prime Z370-A ATX Motherboard
Asus Thund​erbolt III​ AIC
16GB (2 x 8GB) DDR4-2133 Memory
Patriot - Spark 256GB SSD System Drive
Patriot - Ignite 480GB SSD Work Drive
Hisense 43" 4K Display
Presonus Quantum
OS - Windows 10 Pro
Handle every stressful situation like a dog. If you can't eat it or play with it, Just pee on it and walk away.
Old 09-15-2018, 08:06 AM
EddieJones's Avatar
Default Re: S3 and MOTU or RME AVB and Windows
The Motu box doesn't do AVB into Windows I think, only USB, but it looks Like the RME would work. We haven't tested it but I don't see why it wouldn't.
Old 09-15-2018, 07:42 PM
LukeHoward LukeHoward is offline
Does Avid have a direction for audio over Ethernet in the studio – is it AVB (S3) or Dante (MTRX)? As an owner of both (which can't interoperate at this time), I am curious
https://lukehoward.com/
Old 09-17-2018, 04:53 AM
jpsexton's Avatar
I think I understand both of these interfaces would connect via USB and show up as an ASIO interface in your computer. The AVB connection would then be a device on the network acting as a bridge so to speak.
What I'm unsure of is how the Ethernet connection would work. It would need to be connected to your computer for Eucon control but also to the MOTU/RME for AVB.
Would I also need a switch or would this function if daisy chained?
Presonus Quantum
OS - Windows 10 Pro
Old 09-17-2018, 11:18 AM
EddieJones's Avatar
AVB has to go through an AVB switch (like the Motu ones) for best performance....put the S3 into the same switch.
Old 09-17-2018, 11:27 AM
EddieJones's Avatar
Avid initially went with the open standard of AVB but others went with the licenced Dante e. We will work with what our customers want (So the Live consoles support both standards)
Old 09-17-2018, 06:16 PM
Not sure if this is what you meant, but AVB requires an AVB switch.
Old 09-17-2018, 06:17 PM
EddieJones's Avatar
Yes. An AVB Switch can handle normal traffic too.
Thunderbolt ASIO Driver For Windows - MOTU unkJE Windows 2 04-08-2016 04:50 PM
FIX... Pro Tools could not set sample rate to specified value "Windows" and MOTU 828x Rockan0n Pro Tools 11 0 09-17-2014 07:38 PM
Motu 192 wont record on Pt 10.3.9 windows system dairyman3833 Third Party Interfaces 2 06-10-2014 07:10 PM
MOTU 4Pre and Pro Tools 10 on Windows 7 franco412 Windows 0 11-23-2012 11:42 AM
DIGI 001 and Motu 2048 MK II or Motu 24i+ Logic Audio cyril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2002 09:08 PM
