  #31
Old 10-22-2018, 07:54 AM
KingTor KingTor is offline
Default Re: Avid LoRo Downmixer
Originally Posted by smurfyou View Post
I do wish the downmixer covered all formats. (Or that PT could act like a mixer and do downmixing without a plugin...).
I would think the consoles have a built in plug-in to do that. One of the powers of Pro Tools' architecture is it lets us design our own consoles (to a point). I can (and have, still often do) set up my own downmixing chain, but I've been working with control surfaces for so long that I'm not up on what real consoles do differently. Downmixer was such a simple and big step forward when it was launched that I didn't really mind it being so limited, and I have yet to feel the need to buy the latest Dolby Surround Tools (or whatever it's called now) which does have the functionality you describe.
Also I always thought it would be nice to have a built in filter for the LFE. Set it in Preferences and forget it, or turn it off if you don't like it.
Yes! I never would have fallen down this rabbit hole were it for that simple setting. Its relatively easily accomplished using a master fader for each stem and a multimono 1 band EQ (which also lets me put some dynamics in the sub to give it more punch), but that was the kind of extra routing that took up too much DSP and voices is our early days.
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
  #32
Old 10-22-2018, 09:54 AM
Consoles can do that easily. It's actually one of the weak points of ProTools that there's no easy way to insert a low-pass on just a single leg of a multi-channel track (or any other single-leg manipulation of multi-channel signals). Luckily there are plugins like StemCell for exactly that purpose.
F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
  #33
Old 10-22-2018, 11:50 AM
BScout BScout is offline
F.
Unlink multi-mono plugins dropped on multichannel tracks and do what you want (bypass multi-channel legs you don't want affected)
(StemCell has other purposes still though -- like redirecting between legs. Much like I prefer Spanner for downmix rather than the built in Avid plugin)
  #34
Old 10-22-2018, 02:22 PM
critictalk critictalk is offline
What is the usual routing within a 5.1/7.1 project for Stereo Downmix using Avid Downmixer?
  #35
Old 10-31-2018, 05:27 PM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
Multi-mono can be awkward and buggy - part of the reason Stemcell was created.
Re: downmixing
Spanner gives you pretty much any format to any other and you have full control over every channel. Or there are presets if you're in a hurry or just need something as a starting point.
But it's worth pointing out that's really not really one "correct" approach to any particular downmix - the content and context should drive the decision making and different parts of the mix need different settings to feel right.
  #36
Old 10-31-2018, 07:09 PM
Amen. If the project is going anywhere but theaters, a large percentage of your audience won't hear your 5.1, so the downmix should not be an afterthought.
  #37
Old 11-05-2018, 11:32 PM
V5V's Avatar
V5V V5V is offline
Originally Posted by minister View Post
L+R phantom has less high-mids than a straight up C channel.
I think I misunderstood what you wrote, because it reads to me like you're saying moving a signal from one speaker to a pair of identical ones will affect the spectral balance. That doesn't compute for me.
Would you please elaborate/clarify?
Lorin Schultz
V5V Audio
Vancouver, BC Canada
  #38
Old 11-14-2018, 05:05 PM
minister's Avatar
minister minister is online now
Sorry, had a short torrent of work to contend with.
It has to do with rooms and their imperfect acoustical summing (unless you are in an amazing Mastering Suite) and HRTF and other things. With stereo giving a phantom center, the Left speaker is delayed getting to the Right ear by about 200ms from the Right speaker along with the wrap around defraction of the head. This leads to a strong drop at 2kHz which also ripples up into higher frequencies. A dedicated center avoids this.
Then there is something called the Law of the First Wavefront. As you move, the Wavefront is not as clear across the frequency spectrum especially in the upper mids in a phantom center image. A dedicated center avoids this.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
  #39
Old 12-16-2018, 01:04 PM
MatzeHD MatzeHD is offline
Use Dolby tools for a good downmix, this is IMO the best way!
I think, if the native 5.1 Surroundmix sounds good and is mastered perfect, then make it like Dolby for a 2.0 Surround Mode, SL+SR=Mono Surround and this inverted mixing to FL and FR with -3 or -6db?, Center was mixed too with -3 or -6db to FL and FR?
The other way was to mix SR to FR and SL to FL,like with the Waves Downmixtools, but you have no Dolby Surround 2.0 compatibility and a bad Downmix in the most cases! Sub i dont know at the moment! :)
We had for a year here a discussion:
http://duc.avid.com/showthread.php?t=393697
  #40
Old 12-16-2018, 01:50 PM
I hadn't realized Dolby had (finally) come out with an AAF plugin. FWIW, the Neyrinck stuff blows doors off the old (TDM) Dolby Surround Tools.
HTML code is On
5.0 to stereo downmixer RecRoom Post - Surround - Video 7 12-14-2016 08:09 AM
5.1 to LCR/LoRo Hardware kaioflex Post - Surround - Video 2 09-03-2015 12:05 PM
DownMixer Jazzbass56 Post - Surround - Video 7 01-21-2014 11:52 PM
Quick 5.1 to 2.0 (LoRo) Crash Mix Question... sunman Post - Surround - Video 10 06-21-2006 12:56 AM
LCR verses LoRo stereo question CLee Post - Surround - Video 9 11-03-2004 03:07 PM
