Old 02-06-2019, 01:42 AM
Eternitas Eternitas is offline
Default How to convert PT Markers from Text / Script?
Hi @ all,
I`m doing postpro work for a client (Film overdubbing). I´m getting the script as text files, for example like this:
00:00:02
text text text text
text text
00:00:29
text text text text
text text
and so on.
Is it possible to convert the Time informations into markers / file splits / whatever to import into PT? Tried EdiMarker, but with no success (text has to be in a special format, and it´s impossible to re-write 90 pages before converting)... Thank you for your inputs!
Regards,
Eternitas
Old 02-06-2019, 02:41 AM
its2loud its2loud is online now
Default Re: How to convert PT Markers from Text / Script?
You can try this but the text will still need to be formatted correctly.
http://petegates.com/pg-pt-session.html
Old 02-06-2019, 06:53 AM
quadraphonics quadraphonics is offline
Edimarker might be able to help with this too.
Originally Posted by Eternitas View Post
Hi @ all,
00:00:02
text text text text
text text
00:00:29
text text text text
text text
and so on.
Regards,
Eternitas
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 02-06-2019, 08:12 AM
Pete Gates Pete Gates is offline
Yes I think both options - mine and Edimarker, have quite strict requirements. I need to look at this at some point as a colleague of mine needed more flexibility with this recently. Won't be happening imminently though I'm afraid.
Cheers,
Pete
Old 02-06-2019, 08:35 AM
Hmm, yes, I thought I could somehow go around this requirements. I´ll try again, perhaps I find a workaround. Thank you for your inputs!
Old 02-08-2019, 07:38 AM
Finally, I found a way to work this out with EdiMarker. But: Really tricky!! (open original Textfile in Excel, filtering time informations from script with excel rules and filters, copy them to a new excel file, insert dummy names in column 1, convert time informations in column 2 to exact timecode format so that EdiMarker would recognize it, export as txt in right format (NO empty fields!), convert to MIDI File in EdiMarker, import in PT as Markers). A lot of try and error, but it finally worked!
Old 02-10-2019, 11:18 PM
papalou papalou is offline
You could probably do all the excel job with a small sed/awk script. Need a little practice, but can save many time.
Old 02-15-2019, 05:12 AM
laori laori is offline
Hello Eternitas,
I have worked on this with proprietary rtf files that contains scenes numbers and Timecodes and some text...
I have made some python scripts that convert rtf to text with filtered scenes numbers and TC, then converts txt into midi file that you can import in PT.
That works for me !
Can you share one of your txt file ?
I'll will see if I can adapt my scripts to it.
Laori
Old 08-21-2022, 02:24 PM
ftlsxp ftlsxp is offline
Originally Posted by laori View Post
Hello Eternitas,
That works for me !
Laori
Hi Laori.
Can you share you script? Or at least give a hint on how to convert text into midi that pt can recognize as markers?
Thanks in advance.
Old 08-21-2022, 03:12 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
If you haven't checked it out already EdiMarker v2 allows you to import marker data from Text and Excel files with the option to align the columns to the EdiMarker fields during import. It can also export an AAF for Pro Tools to import rather than MIDI which allows you to append markers within Pro Tools and transfer marker comments.
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
HTML code is On
Export markers as text file? peter5992 Post - Surround - Video 3 11-22-2011 06:42 PM
OSX/Win app to convert markers into text files mfranken Post - Surround - Video 4 10-21-2010 11:33 AM
Export markers as text idris Pro Tools TDM Systems (Mac) 1 09-10-2010 06:06 AM
I need to export markers as text! bad jitter Pro Tools TDM Systems (Mac) 1 08-27-2008 09:47 AM
exporting markers as text? AdamFrick Pro Tools TDM Systems (Mac) 3 06-05-2001 06:33 AM
