Setting up MIDI drum sounds/building MIDI click
Greetings,
I want to build MIDI click tracks for a band/drummer who request more live sounding time reference.The drummer plays very stiff to a metronome sounding click and is a tasty drummer but tends to speed up a touch and gives songs some "slipping".Traditionally ,I would just set up a click but they requested I build some MIDI drum sounds.I also should probaly hone my MIDI skills or lack there of.I have never ( under 5)really worked with MIDI ever so an entire walk thru would be ideal.I have navigated into my Indigo Plug in and looked at sound banks.How do I get these into session ?set tempo? any and all ifo would be very helpful. thank you.
ORyan Productions/Studio X23/WuLi Records |
Re: Setting up MIDI drum sounds/building MIDI click
Same problem here. I'm a drummer. I've done sessions where I've brought in my own drum machine and used sounds to create a MIDI click. Way, Way better than the stock clicks sounds in PT. Problem is, some engineers don't know how to do this and since I don't know how myself I always get stuck using the stock click. I've got a session next week and want my own click! I know the engineer doesn't know how to do this. Teach me how so I can show him, please!!!
Well All Yall, can do it the "Fancy new way" if you've Pro-Tools 7 - insert your softSynth of choice on an "Instrument Track" draw 4 1/4 notes, 1/8th notes (What ever you prefer) on what ever note=sound you'd like to trigger - Quantize the Bar, then Alt+R to repeat for how many number of bars you want your click.
You can set up a click, in 10 seconds. If you're using an earlier version of pro tools.... Insert your softSynth on an Aux - Create a Midi track - Set the Midi track's output to the Softsynth - then... draw, or play your first bar of click as described above, quantize it, and repeat, or duplicate that bar. It'd be a nice improvement on PT's Click pluggin to be able to load your own sound file.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
My way: I create two click sounds I like, one for first beat and the second for other beats. I place one at beat one, the other at beats 2, 3, 4 (etc.) in an audio track while set to Grid. Then I copy that bar as many times as I need and - VOILA - sounds I like, no latency issues, etc. If you need it external the Protools session, just solo it and burn to disc.
steve Your Heaven |
no midi drum sounds during playback | Tibby | macOS | 0 | 06-12-2012 09:36 PM |
Triggering MIDI sounds through drum pad | JohanMN | MIDI | 2 | 09-03-2010 02:33 AM |
MIDI Click sounds | rolan | General Discussion | 1 | 11-08-2005 10:21 PM |
Click using MIDI drum sounds | WoodnWire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-23-2004 06:37 PM |
Awesome drum midi sounds! | Ross H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-12-2003 08:56 PM |
