Guitar Input Stopped working -
Ok so now i am really confused, Turned my eleven rack on and plugged in and nothing no sound... tried the tuner and nothing , I dont believe I inadvertantly changed anything so i did a "reset" via the front panel on the unit and it is still not working , am i missing something else to try, tried 2 different guitars and 3 cables... This is my 4th time actually using it.. very confused...
thanks Dave |
Re: Guitar Input Stopped working -
after turning it on and off a few times by the power on selector switch on the front to no avail.... I figured i would pull the power cord.... after plugging it back in that seems to have done the trick ...
It was like it was frozen.. i didnt catch it at first because i was able to use the dials and scroll, but the tuner was stuck on F .. anyone else have this happen? should i be concerned? Dave |
Arrrgggg I just can't face typing "clock problem" again (oops I just did).
See this thread and if you have a problem again do the test Chris suggests there to see if you have the clock hardware problem. If so contact Avid support. Darryl |
Thanks Darryl. It not much fun for me either.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
REg card says rev E but last digit on the s/n is an H on the unit... so pretty much wait until it does it again and switch the clock cycle? Or just call support ?
DULrich, I would wait until it happens one more time, and do the sample rate test just to be sure that's the problem. It would be a pain for you to send it in, if that wasn't really the problem. I would appreciate it if you'd let me know the result. You can send me a private message via the DUC.
Thanks Chris, when it happens again ill let you know ..
well it did it again .... clock said 44.1 as soon as i cahnged it to 48 ... it worked...
They will sort it out for you.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
yea they are closed today ... very dissapointed as its been kind of sitting and i was finally making some head way today in using it
Guitar Input not working | radman56 | Eleven Rack | 6 | 03-09-2014 11:10 AM |
My spdif input stopped working (003) | Paul David | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2010 10:23 AM |
Midi input stopped working on Mbox 2 Pro | mrshonuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-07-2009 09:28 PM |
Why has midi input stopped working except with Midi Thru enabled? | Martin Dubka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-11-2008 07:43 AM |
lightpipe input stopped working | jgehring | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-26-2002 07:55 AM |
