Old 12-23-2009, 01:18 PM
crizdee's Avatar
crizdee crizdee is offline
Default Control 24 modifier keys broken in 8.0.3
Since updating to 8.0.3 the modifier keys don't seem to be working any more
Stuff like...
Command+S (save)
Command+shift+N (new track)
Command+G (groups)
none of these are working from the control 24
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 12-23-2009, 05:02 PM
crizdee's Avatar
Default Re: Control 24 modifier keys broken in 8.0.3
If someone with a control 24 and or a control surface can check this!!
After trash prefs its still broken what a pain!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-23-2009, 06:44 PM
Syn-g Syn-g is offline
All modifier keys are working as it they should here with a C|24 control surface & 8.0.3/OSX 10.5.8
PTHD6 / C|24 Controller / Euphonix MC Mix Controller / PT v.10.2
Intel MacPro 2.8ghz Quad Xeon / 18gigs ram/ PE6R4 Expansion Chassis w/Core,4 accel,1 process card, 46" & 24" monitors
Syn-g
www.bulletsage.com
Old 12-24-2009, 05:53 AM
crizdee's Avatar
Thanks for checking with the new C/24. i would have thought the drivers were the same, maybe not then.
Anyway i have booted up my clone of 8.0.1 and the modifier keys on the original Control 24 are still working ok, so its 8.0.3 that has broken this
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-24-2009, 07:44 AM
Bob Brown Bob Brown is offline
Are you sure you updated the control surface personality files when you moved to 8.0.3?
Old 12-24-2009, 09:14 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Chris ... All those key commands are working here with 8.03 on my control 24. On the first start of 8.03 it forced my c24 to power cycle ...
Ainslie
http://www.ainsliegrosser.com/
2013 MacPro 6 x 3.5 32GB OS10.14.4 HDX2 Sonnet Chassis, PT2019.5. Macbook 2018 Watch this to follow mobile mix studio build coming: https://youtu.be/cbqMTjCVj9I
Old 12-24-2009, 09:25 AM
crizdee's Avatar
I thought it was installed with the update!! i'll check this though, but everything else is working ok.
Ainslie
Thats strange! i had to go to peripherals and reset the ethernet controllers as normal, but i'll check further.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-24-2009, 09:41 AM
crizdee's Avatar
Ainslie
Hi Ainslie,
Checking further the problem is that the control 24 modifier keys don't work in conjunction with the apple QWERTY keyboard.
Press command+shift on the control 24 and "N" on the qwerty should bring up new track window. but it doesn't for me in 8.0.3
So this is definitely working for you?
I have checked the personality/control 24 bundle and its info states version 8.0.3 11th December 2009
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-24-2009, 10:18 AM
crizdee's Avatar
I've had a couple of total freezes since installing 8.0.3 so i am uninstalling. clean uninstall and installing 8 then 8.0.3 update.
See if this makes a difference to this issue and others
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-24-2009, 11:11 AM
crizdee's Avatar
Uninstall and fresh install of 8 then 8.0.3 and control 24 modifier keys are still not working in conjunction with the QWERTY keyboard
for example: command+shift (on the control 24) plus "N" on the qwerty keyboard should bring up the new tracks window?
Chris
Producer, Engineer,
www.ukmastering.com
Function keys on Control 24 stardancer ICON & C|24 4 12-16-2012 10:20 PM
D-Command Modifier keys not working Touchwood Studios ICON & C|24 3 03-01-2011 10:12 AM
Session import Modifier Keys Inconsistency TommyT Pro Tools TDM Systems (Mac) 1 10-12-2010 08:14 AM
C|24 Modifier Keys in 8.0.3 paulmellors ICON & C|24 1 02-10-2010 09:46 AM
Modifier keys...anyone remember Workman Pro Tools TDM Systems (Mac) 7 10-24-2005 04:08 AM
