OT - Help with Samples
Although I use PT this is slightly off topic.
I'm not very technically musical (is there such a thing?) so am having diffficulty finding correct samples... For example, instead of working out that a drum track i need is (e.g.) '4 on the floor with heavy hi-hat' (told you I'm not technically musical!), is there anywhere i can go to purchase/download samples that may be, for example, the complete drum track to 'Complicated' by Avril whatsername, that is also high quality and technically correct, rather than purchasing a professional midi track and connecting it to a keyboard? This may make more sense if I explain that I am trying to become totally portable (powerbook, emi 6/2, etc) and do away with having to carry a keyboard around with me... Cheers Al |
Re: OT - Help with Samples
You might want to check out Discrete Drums...they are real drum tracks prearranged in PT sessions, so you can cut them up and make your own beats and also have individual track control for mixing.
I haven't tried it myself (it's a litte expensive), but I've heard good things about it. There are also other, similar products out there. I currently am using either my JV-1010, Reason 2.0, or Kontakt sampler for programming drum tracks using midi. Good Luck!
The Burner |
using PT8 in 24 nit with 16 bit samples | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-02-2010 11:05 PM |
samples | soulcactus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-28-2007 10:01 AM |
Have I been off by 164 samples all along? | scottevl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 55 | 01-18-2004 05:26 PM |
EMU samples into Mac SSC | Renie | Digidesign Hardware & Software | 3 | 11-15-2001 08:57 AM |
samples | SNAPPER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-09-2000 03:12 PM |
