Old 12-20-2022, 05:40 AM
Toddao_Software Toddao_Software is offline
Default Absentia DX 3.3 is released with the new Assembly Fix Sync (AFS)
What´s new?
- Assembly Fix Sync* saves time on Dialogue Assemblies. It corrects the offset between the AAF clips and the expanded channels in Pro Tools.
- M1 & M2 Apple Silicon machines can now run Absentia DX natively.
- Hum Remover "Smooth Under Dialogue" catches the low-end hum that overlaps with voice fundamentals.
- Air Tone Generator "Replace All Hybrid" is an average of "Natural" & "Flat" algorithms.
- Air Tone Generator "Cut Dialogue" creates roomtone from a full scene, by cutting out the voices and leaving the silences between sentences.
* Assembly Fix Sync is only compatible with Mac OS 10.14 and above.
See Assembly Fix Sync in progress
https://youtu.be/oogV031KS70
Absentia DX v3.3 is a free update for all active Server and iLok license holders.
More info at https://absentiadx.com/
[IMG] code is Off
EdiLoad v5 has been released with new Assembly window mfranken Partner Announcements 7 03-28-2024 04:18 AM
Control 24 fader pcb assembly Davidwilson ProControl, Control|24, Command|8 0 06-17-2019 12:39 AM
Absentia DX -- New Software From Todd-AO conleec Post - Surround - Video 12 04-12-2019 11:14 AM
AAX Developer needed for Absentia DX Rob Nokes AAX Plug-ins 4 01-22-2018 01:25 PM
Production Assembly?? Naylorfreak Post - Surround - Video 0 04-06-2012 12:04 PM
